krtk0 Posted March 15, 2011 Share Posted March 15, 2011 Zdravim, potreboval by som poradit s tymto - kontrolka motora vobec nesvieti (ani pri otoceni kluca). Ale - scantool.net vyhadzuje P0135 a pise ze MIL on, tj ze by mala byt kontrolka zapnuta. spekulujem, ci nahodou predosly majitel nejak nedeaktivoval tu kontrolku VAGom aby sa nerozsvecovala vobec. da sa to? Ak hej, to by bol asi lepsi pripad, lebo "Jak na to" pre oktaviu pise, ze ak je odidena LEDka v palubovke, tak treba palubovku vymenit. diki za pripadnu odpoved:) Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted March 16, 2011 Share Posted March 16, 2011 ZAKLADNE UDAJE O AUTE!! Quote Link to comment Share on other sites More sharing options...
krtk0 Posted March 16, 2011 Author Share Posted March 16, 2011 Octavia 1.6 75kW, 2002 AVU motor Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted March 16, 2011 Share Posted March 16, 2011 (edited) Kontrolka motora musi svietit. Po nastartovani musi zhasnut. Led dioda-smd v budiku sa da aj preletovat nemusia sa menit komplet budiky. Ty si v GB?? Treba to napichnut na diagnostiku a kontrola akcnych clenov. Edited March 16, 2011 by PROCHY603 Quote Link to comment Share on other sites More sharing options...
krtk0 Posted March 16, 2011 Author Share Posted March 16, 2011 ok, tak s tym niekam zajdem nech to napichnu a pozru. aspon sa mi ulavilo, ze aj ledky sa daju "opravit". dik. inak,.. tesne, som v dublinovi Quote Link to comment Share on other sites More sharing options...
wire Posted March 17, 2011 Share Posted March 17, 2011 (edited) Zdravim ja mam oktviu 1,9 tdi 2000ku 81 kw a pri zapnuti klučika tiež nesvieti kontrolka v lavom velkom budiku /kontrola motora-mala by ?/ auto je dovezene s nemecka a kniha chyba ,v tom budiku su dve kontrolky a nesvieti ani jedna. na diagnostike nevykazuje ziadnu chybu.ďakujem za info Kontrolka motora musi svietit. Po nastartovani musi zhasnut. Led dioda-smd v budiku sa da aj preletovat nemusia sa menit komplet budiky. Ty si v GB?? Treba to napichnut na diagnostiku a kontrola akcnych clenov. Edited March 17, 2011 by Wojnar Je problém si příspěvek před odesláním prohlídnout? Quote Link to comment Share on other sites More sharing options...
Wojnar Posted March 17, 2011 Share Posted March 17, 2011 Myslíš EPC? Ne. V levém akorát kontrolka airbagu, v pravém všechny. Quote Link to comment Share on other sites More sharing options...
wire Posted March 17, 2011 Share Posted March 17, 2011 (edited) ja mam ine bidiky ako su na obrazku v strde medzi budikami je display s kontrolkami ,tam tiez nesvieti signalizacia zapnutych pasov a v tom velkom lavom je signalizacia motora s bleskom a trojuholnik v nedotiahnutom kruzku .neviem ci by mali fungovat tieto tri kontrolky.zoskenujem display a dolozim ho Edited March 17, 2011 by Wojnar Poslední příspěvky se necitují! Quote Link to comment Share on other sites More sharing options...
wire Posted March 17, 2011 Share Posted March 17, 2011 (edited) EDIT: tak tu je ta moja pristrojovka,dam novy obrazok vyznačim tie kontrolky EDIT2: tak tu je ta moja pristrojovka s označenymi kontrolkami Edited March 17, 2011 by Wojnar Quote Link to comment Share on other sites More sharing options...
Wojnar Posted March 17, 2011 Share Posted March 17, 2011 (edited) Že si máš po sobě, před odesláním, kontrolovat příspěvky, jsem Ti už jednou napsal! Že se necitují poslední, je v pravidlech! Když se citují, tak tak aby to jako citace vypadalo! V pravidlech je taky povinnost editovat stávající svůj příspěvek a nepsat dva a více svých příspěvku po sobě v krátké době! A teď k věci. Co je to za kontrolka ta vlevo v levém budíku, ta rozmazaná? Je to stejná co na mojem obrázku v pravém budíku první zleva? Tak ta by rozhodně při zapnutí zapalování svítit měla. Pokud máš ASR nebo ESP tak i ta druhá. Kontrolka zapnutí pásů svítí po zapnutí zapalování a pokud není zapnutý pás tak zní i gong. To to, ale závisí podle výbavy auta. Edited March 17, 2011 by Wojnar Quote Link to comment Share on other sites More sharing options...
krtk0 Posted June 15, 2013 Author Share Posted June 15, 2013 tak som na to prisiel - a zrejme to bude aj pripad wire - auto kupene od ruky. rozobral som budiky a tie ledky motora (a najnovsie som zistil, ze aj airbag) boli proste zozadu - zo zadnej strany pozadia prelepene ciernou izolackou, takze si kontrolka motora mohla svietit kolko chcela takze ponanucenie pre ostatnych s autom od ruky - ked svetielka nesvieta a diagnostika nic neukazuje, treab odlepit pasku Quote Link to comment Share on other sites More sharing options...
Recommended Posts
