Sign in to follow this
chiper
6MT extraneous noise
Recommended Posts
Good day
Skoda Octavia A7fl 2017 1.4 (CZDA) 6MT
I have 2 problems.
1) On the cold, when you start the engine there is an unpleasant knock that comes from the gearbox. When you squeeze the clutch - the sound disappears. When this sound also disappears when the car is warming up. Here's an example of sound: https://www.youtube.com/watch?v=I6hovqn034M
2) Also on the cold, the speeds turn on very hard. It so happens that you can turn on only by force. As a rule, everything passes when the car is warming up.
The mileage of the car is 30000km. At the same time, the dealer sees no problem.
Share this post
Link to post
Share on other sites
Guest
Reply to this topic...
