kenny_fx Posted July 12, 2009 Share Posted July 12, 2009 Zdar chlapi, kamos mi vymenil lozisko a od te doby mi na palibnim pc sviti opotrebeni desticek, pritom jsou desticky OK. Nevi jak to ma vymazat. Poradite nekdo? Predem diky Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted July 12, 2009 Share Posted July 12, 2009 Neposkodil -neprerusil nahodou kabel ktory ide do platnicky??? Alebo kabel na signalizaciu ktory pokracuje po tlmici do karoserie.??? Quote Link to comment Share on other sites More sharing options...
kenny_fx Posted July 12, 2009 Author Share Posted July 12, 2009 to nevím, nebyl jsem u toho když to dělal. Ale zkoušel vypojit konektor z desticky (odpojit) a stejne to sviti. Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted July 12, 2009 Share Posted July 12, 2009 Ked ten konektor rozpojis tak ti bude svietit ta kontrolka.Odpoj baterku na cca 1 hodinu. Quote Link to comment Share on other sites More sharing options...
kenny_fx Posted July 12, 2009 Author Share Posted July 12, 2009 Kdyz odpojim konektor od brzdove desticky, tak to prece muze vypadat jako ze nemam desticku se sensorem... ok zkusim odpojit baterku na 1 hodinu, se zapojenym konektorem? Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted July 12, 2009 Share Posted July 12, 2009 (edited) NIE TA PLATNICKA MUSI BIT ZAPOJENA.!!!! Zapoj konektor co ide z brzd.dosticky. A potom na 1.hod odpoj baterku. Edited July 12, 2009 by PROCHY603 Quote Link to comment Share on other sites More sharing options...
kenny_fx Posted July 19, 2009 Author Share Posted July 19, 2009 Tak na hodinu odpojena baterka a nic.... Quote Link to comment Share on other sites More sharing options...
kenny_fx Posted July 19, 2009 Author Share Posted July 19, 2009 a kabel od desticky je utrzeny a pajkou připajeny k sobě (to dělal ten mistr debil). Quote Link to comment Share on other sites More sharing options...
lukash Posted July 19, 2009 Share Posted July 19, 2009 Tak kamoš nebo debil ? Pokud netrváš na senzoru opotřebení, tak si nechcej překodovat budíky. Quote Link to comment Share on other sites More sharing options...
kenny_fx Posted July 19, 2009 Author Share Posted July 19, 2009 tak když je to utrženy, tak už jedině koupit novou destičku.... pokud chci mit sensory, je to tak? Ale stejně když je to ted spojene, tak to stejne sviti... divne. Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted July 19, 2009 Share Posted July 19, 2009 To bol EXPERT co ti opravoval auto Rozhodil geometriu+poskodil platnicku. Ten kabel poriadne zaletuj a signalizacia prestane svietit. Len to opotrebovanie platniciek si musis kontrolovat sam vizualne. Quote Link to comment Share on other sites More sharing options...
kenny_fx Posted July 19, 2009 Author Share Posted July 19, 2009 No jo bohužel, "expert". Ono to je zaletovane, a stejne sviti. Muze tam byt jeste neco spatne? Quote Link to comment Share on other sites More sharing options...
PROCHY603 Posted July 19, 2009 Share Posted July 19, 2009 Zaletovane ale ako???? Zober kus drotu a prepoj ten konektor co ide z karoserie do coho zasuvas konektor z platnicky. Quote Link to comment Share on other sites More sharing options...
lukash Posted July 19, 2009 Share Posted July 19, 2009 Vezmu ohmmetr a zkusím na konektoru destičky jestli je tam propojení. Pokud ano tak by mohl být problém ve směru do auta... pokud by měl být problém ve směru do auta, tak napíchnou na VAG a překodovat budíky, bez signalizace opotřebení... Quote Link to comment Share on other sites More sharing options...
Recommended Posts
