cranked
  1. Zdravim mam podobný problém. Auto mi padá do nouzáku a občas mi svítí kontrolka emise do dílny. Auto jsem napíchl na diagnostiku a vyjelo mi toto. Ps: váhu vzduchu jsem měnil. 17056 - Cylinder 2 Glow Plug Circuit (Q11) P0672 - 000 - Electrical Fault Freeze Frame: RPM: 882 /min Torque: 53.7 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 13.98 V Bin. Bits: 11000100 Temperature: 14.4°C Bin. Bits: 10110000 16622 - Manifold Pressure / Boost Sensor (G31) P0238 - 000 - Signal too High Freeze Frame: RPM: 1596 /min Torque: 0.0 Nm Speed: 41.0 km/h Load: 0.0 % Voltage: 14.44 V Bin. Bits: 11000000 Absolute Pres.: 1071.0 mbar Absolute Pres.: 2386.8 mbar 18000 - Altitude Sensor / Boost Pressure Sensor P1592 - 000 - Implausible Correlation Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 12.31 V Bin. Bits: 00000100 Absolute Pres.: 979.2 mbar Absolute Pres.: 2182.8 mbar 16485 - Mass Air Flow Sensor (G70) P0101 - 000 - Implausible Signal Freeze Frame: RPM: 1386 /min Torque: 0.0 Nm Speed: 35.0 km/h Temperature: 7.2°C Absolute Pres.: 1407.6 mbar (no units): 60.0 (no units): 1.52 Temperature: 87.3°C 18017 - Crash Shut-Down Activated P1609 - 000 - - Intermittent Freeze Frame: RPM: 777 /min Torque: 148.8 Nm Speed: 19.0 km/h Load: 89.4 % Voltage: 12.77 V Bin. Bits: 11000111 Torque: 165.9 Nm Torque: 319.6 Nm
