adiserv
Vše, co zveřejnil adiserv
  1. I bought 5j0 .. and the camera works at the reverse. (But you also need a delay box, keep the camera powered for 8 seconds longer.) If you want to run the camera mount rcd 330g on another car with can 2.0 and activate with vcds the reverse function. Good luck
  2. I installed an extended menu version. (search on 4pda forum ) and for about two weeks I have dedicated GPS module and I have finished running tests.
  3. Then I'll stick with the emulator. Time synchronizes with gps module, camera works, bluetooth. Maybe I'll buy a 5j. and I'll try to see, but I do not want to lose the camera. some photos with gps. come back next days with video.
  4. with the software change you can watch the video without any restrictions (the supported format is wmv the camera works, just activate rcd 330 with vcds on another machine (skoda, vw does not matter, block 4 bit6) I have experience in electronics, but connecting the emulator does not do it in parallel. I think it's okay. You have to remove can + and can- from the machine and enter the ones in the emulator. The emulator translates electrical signals into can info. You still need + lights and + contact for everything to work ok. Time and temperature are not synchronic. I tested rcd on machine without emulator and synchronized time. i want to see if anyone has 5j0035751 installed on the car, and rcd 330g encoded (camera activated on other car) if it works? it's possible to go. At the gps module I'm working, I come back with the video when I'm done.
  5. I bought a can emulator on ebay. Without this emulator, rcd does not recognize the key and can not use bluetooth. You have to disconnect can + and can- from the car and connect the ones from the emulator. Camera activation must be done on another car with 2.0 can. I put rcd to start when i switch the key on. Changes: changed the lights in green, changed the logo (the original was vw), changed the color theme (the original was in yellow) now is green. It can also be red for vw. I've unlocked windows and installed the extended menu with the gps menu, easy connect (similar to mirrorlink but goes with all the phones), the second music player (if you want gps and music at the same time, video player, and a total comander. The quality of presentation video is not great. When I have time i do another. I'm currently working on the gps module,it just arived from ebay. https://www.ebay.com/itm/Canbus-Gateway-Emulator-Simulator-Decoder-For-VW-Radio-RCD330-RCD330G-Plus-MIB/222744376243?hash=item33dc9973b3:g:HzAAAOSwQcJaJkUj https://www.ebay.com/itm/NEO-7M-GPS-Satellite-Positioning-Module-for-Arduino-STM32-C51-Replace-NEO-6M/311876309386?hash=item489d46d18a:g:i48AAOSwbopZUH26
  6. I've solved the problem with a can emulator. . It works, except the time and temperature do not synchronize.We turn on the camera on another machine. I changed the LED, start logo, tunning menu installed (more for easy connect). I'll buy the can 5j0035751 and I'll put it to have the time and temperature synchronized. It is a great upgrade from Skoda Dance.
  7. Přeložil jsem google a doufám, že to bude pochopeno
  8. Dobrý den. Koupil jsem rcd330 desay nainstalovat jej na skoda fabia 2 (2008). Nyní hledám adapter 5j0035751. Chci vědět, zda adaptér potřebuje být kódován, je-li zobrazen maxidot a zda je zobrazen správný čas?
