Skoda octavia 2017 entering to the safe mode / Škoda Octavia 2017 přechází do nouzového režimu
@VeteranChild Hello again, Also I have noticed on the VCDS that Particle filter outlet temp.sens.1 bank 1: raw value: -40 and voltage is 0.0000 Do you maybe know which sensor is that or where is the location of it?
Hello again everyone. I have checked rubber hoses on the intake and there is no cracking. Also, I had some test drive and logged some data into csv file. In some places you can see that coolant temerature is going to the 100. Also, if you need some other parameters, I can log it. You can use vaglogs.com to see it better. Also, there is the higher boost pressure 2.573 mbar. Is it too high maybe? LOG-01-IDE00025_&7.CSV
Thank you for the response. Next week I will check all rubbers and I will tell you results. Thanks again man!
Hello everyone, I'm from Serbia and until now I did not manage to find solution for my Skoda Octavia also not in official skoda service. CAR: Skoda Octavia 1.6 85KW DSG 2017. production year. So the thing that happing to me is following: In the colder days everything is working fine, but when the weather is warmer and when I'm driving uphill, firstly everything is okay but after 500m-1000m the skoda is entered into safe mode without any indication on the instruments and also on the diagnostics tool. No errors or anything. I have changed intercooler and the situation is the same. Some of my friends also have the same issue but still today we did not manage to resolve it. My friend turned to EGR and DPF and also cleaned whole coolant system but the same thing happening. If you need more info you can send me email to the dejanristanovic@hotmail.com. Also, if you need specific parameter from VCDS, I can send a screenshot. I would really helpful if someone help me or if someone had similar issue and resolved it. AI translated to CZ language: Zdravím všechny, jsem ze Srbska a až do teď se mi nepodařilo najít řešení pro můj vůz Škoda Octavia, a to ani v oficiálním servisu Škoda. AUTO: Škoda Octavia 1.6 85KW DSG, rok výroby 2017. Co se mi děje, je následující: V chladnějších dnech vše funguje bez problémů, ale když je tepleji a jedu do kopce, nejprve je vše v pořádku, ale po 500-1000 metrech se Škoda přepne do nouzového režimu bez jakéhokoli upozornění na přístrojové desce nebo v diagnostickém nástroji. Žádné chyby ani nic podobného. Vyměnil jsem intercooler, ale situace je stejná. Někteří z mých přátel mají stejný problém, ale dodnes jsme ho nedokázali vyřešit. Můj přítel se zaměřil na EGR a DPF a také vyčistil celý chladicí systém, ale děje se mu to samé. Pokud potřebujete více informací, můžete mi napsat na email dejanristanovic@hotmail.com. Pokud potřebujete konkrétní parametry z VCDS, mohu poslat screenshot. Bylo by opravdu užitečné, kdyby mi někdo pomohl nebo pokud někdo měl podobný problém a vyřešil ho. Děkuji.
dejanrs
