kikitron
  1. I think that the Oxygen (Lambda) Sensor Heating: B1 S2 is Lambda behind catalyst. B1 - bank 1 S2 - sensor 2 Am i correct? How much Eur,- is 4966,-Kč ? @DIAGNOSTIK, what did you mean with " sonda KO" ??
  2. Hy! I have Skoda Fabia 1,4 MPi, ATZ, 50kW, year 2000 and i have problems with my lambdasonde. The VAG test is: VAG-COM Version: Release 311.2-N Control Module Part Number: 047 906 033 A Component and/or Version: 1,4l SIMOS3PA 00HSSJ48 Software Coding: 00021 Work Shop Code: WSC 13765 Additional Info: TMBNB46Y9Y3055240 SKZ7Z0Y0517288 2 Faults Found: 17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit P1118 - 35-00 - - 16524 - Oxygen (Lambda) Sensor B1 S2: No Activity P0140 - 35-10 - - - Intermittent Is possible to get some universal lambdasonda?? Or i have to buy only original?? If it is possible, is the Bosch lambdasonda ok and witch one? (model,number) The sonda has 4 wire. Sorry on my bad english. Best regard, Kristijan
