Tomik9999
  1. Ja mam firmware 5274 a nemam zadny problem... I kdyz je pravda ze muj sup je 2010ka. Kazdopadne pokud by to neslo odstranit, tak bych zkusil zmenit firmware. Jen si zjisti, jaky muzes do sve jednotky nahrat. Nektery ti muze bricknout jednotku.....
  2. I flashed 5269. No recoding required.But now i have a little problem. The car is always 5-10m behind the real position on the street. I did a factory reset on navigation and navigation memory and drove about 20 minutes in the city.First impression was ok but after 20 minutes the position start to lag behind. I have the antena mounted in the dash, 6-7 sat 3d fix all the way but inaccurate positioning.Can i install 5270 or can i go back to another fw ?Thanks for the help Odpoved znela .I had a similar issue after upgrading. Time was incorrect on the vehicle compared to the GPS. Correcting the time and a reset of the Nav to default settings improved things ~80%. Things were 100% after a 40 minute round trip. Snad to pomuze...
  3. Ahoj. Cetl jsem kdysi na jinem foru, ze mas nejakou dobu (pul hodky tam myslim psal) jet se zaplou navigaci, ale bez naplanovane trasy. Pak zastavit, vypnout motor. Melo by se to srovnat. Nevim jestli to funguje, ale za pokus to stoji. Pak dej vedet, jak jsi dopadl ;-) T.
