vancak
    3
Vše zveřejněné uživatelem vancak
  1. Zdravim vsetkych, sory ak tu take vlakno je ale som v koncoch a neviem co dalej tak by som poprosil touto cestou o radu. Dnes som odpojil baterku zhruba na cely den na aute: Fabia 1,9TDI r.v.2001 z dovodu vymeny serva a po opetovnom napojeni baterky auto vobec nejde nastartovat a VAG stale dava tieto chyby: Monday,21,May,2012,17:59:57:55371 VAG-COM Version: Release 704.1 Data version: 20070422 Chassis Type: 6Y - Skoda Fabia Scan: 01 02 03 08 09 15 17 19 25 37 44 46 56 76 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-019-100.LBL Part No: 038 906 019 AF Component: 1,9l R4 EDC G710SG 1056 Coding: 00002 Shop #: WSC 13765 TMBMS26Y613108143 SKZ7Z0Y0583209 3 Faults Found: 17977 - Cruise Control Switch (E45): Implausible Signal P1569 - 35-00 - - 18056 - Powertrain Data Bus: Failure P1648 - 35-10 - - - Intermittent 17978 - Engine Start Blocked by Immobilizer P1570 - 35-00 - - Readiness: 0 0 X X X ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No: 6Y0 820 045 Component: Klimaanlage X0760 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: None Part No: 6Q1 937 049 Component: BORDNETZ-SG. 1S30 Coding: 09402 Shop #: WSC 13765 6 Faults Found: 01309 - Power Steering Control Module (J500) 49-00 - No Communications 01321 - Control Module for Airbags (J234) 49-00 - No Communications 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications 01316 - ABS Control Module 49-00 - No Communications 01314 - Engine Control Module 49-00 - No Communications 01312 - Powertrain Data Bus 37-00 - Faulty ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 6N0-909-901.LBL Part No: 6N0 909 901 Component: Gateway K<->CAN 1S30 Coding: 00014 Shop #: WSC 13765 6 Faults Found: 01309 - Power Steering Control Module (J500) 49-00 - No Communications 01321 - Control Module for Airbags (J234) 49-00 - No Communications 01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications 01316 - ABS Control Module 49-00 - No Communications 01314 - Engine Control Module 49-00 - No Communications 01312 - Powertrain Data Bus 37-00 - Faulty ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 6Q0-959-433.LBL Part No: 6Q0 959 433 C Component: 07 Komfortgerát 0002 Coding: 00259 Shop #: WSC 04938 Part No: 6Q1959801A Component: 05 Tőrsteuer.FS TFK 0003 Part No: 6Q1959802 Component: 07 Tőrsteuer.BF TFK 0002 Part No: 6Q0959811 Component: 07 Tőrsteuer.HL TFK 0002 Part No: 6Q0959812 Component: 07 Tőrsteuer.HR TFK 0002 1 Fault Found: 01312 - Powertrain Data Bus 79-00 - Please Check Fault Codes End -------------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------------------- S elektrikou som vobec nic neporabal okrem odpojenia a napojenia noveho serva. PROSIM PROSIM PROSIM neviete v com je chyba??? Vdaka za akukolvek odpoved.
  2. Zdravim, podla mojich skusenosti su to vadne tie uhlikove voditka. Tiez som s tym mal prpblem, skusal som to cistit a stale nic raz to slo a raz nie. Tak potom som na skusku napajkoval tenky drotik medzi kontakty ktore ma prave ten bezec po tych uhlikovych voditkac spinat a od tej doby mam s tempomatom pokoj. Jediny problem je v tom ze teraz si nemozem na packe tempomat vypnut je na trvalo zapnuty. Ale vzdy lepsie ako ked to nefungovalo vobec. Mozno nejaky odbornik na elektro by mohol ozrejmit preco to prestalo fungovat s tymi uhlikovymi voditkami a ci sa to da nejako zrepasovat.
