dkarolj
  1. Hello, you need to update also the DSG computer to solve this problem. My version is updated from 1907 to 1955. It is described in TSB Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 012 F HW: 02E 927 770 AJ Component: GSG DSG AG6 440 1907 Revision: 04844002 Serial number: 00000904021011 Coding: 0000020 Shop #: WSC 35110 377 00999 VCID: 1325094E32758EDCB5-8046 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 3T0 907 379 C HW: 3T0 907 379 C Component: ESP MK60EC1 H45 0106 Revision: 00H45001 Coding: 843DA01619220000211205E4981E0041AB00 Shop #: WSC 80093 222 69422 VCID: 3D718FF6A471A8AC33-8068 No fault code found. Condition 01 14 04 February 19, 2014 2028625 Supersedes Technical Bulletin V011327 dated August 13, 2013 to include additional model year and update the software levels, SVM code and part number. Update Programming ECM to Eliminate DTC 03366 Stored in Brake Electronics Fault Memory Customers may complain of a Brake Warning Light ON in the instrument cluster. Tip: This software update is designed to re-program both the ECM and TCM with new software. The re-programming itself should carry out the updates without technician intervention. Please ensure both ECM and TCM software has been updated after the flash is completed. The following fault code may be stored in the Brake Electronics Fault Memory: DTC Description 03366 Brake electronics - (03366) Vacuum Sensor -G608 Implausible Signal Technical Background If vehicle is equipped with an automatic transmission, TCM must be reprogrammed along with the ECM. If vehicle is equipped with a manual transmission, TCM reprogramming is not possible. This condition occurs due to an incorrect sampling rate between the ECM and the G608 Vacuum Sensor. The symptom as described will store the fault 03366 in the Brake Electronics Fault Memory. This fault will cause the Brake Warning Light to display in the instrument cluster DO NOT replace any parts for this condition. The condition as described does not affect vehicle braking performance or operation.
