lumirb
  1. Zdravím, nevíte kde může být problém: EmergencyApp-MIB: version 30.951, date of build 12.01.2015 IPC watchdog is DISABLED Display: BGColor normal Display: Version 30.951 Display: Info1Text Update in Progress Display: Info2Text Starting up. Display: Info3Text Please Wait... ERROR: /net/mmx/ramdisk/eassist doesn't exist Failed to output BGColor normal ERROR: /net/mmx/ramdisk/eassist doesn't exist Failed to output Version 30.951 ERROR: /net/mmx/ramdisk/eassist doesn't exist Failed to output Info1Text Update in Progress ERROR: /net/mmx/ramdisk/eassist doesn't exist Failed to output Info2Text Starting up. ERROR: /net/mmx/ramdisk/eassist doesn't exist Failed to output Info3Text Please Wait... sendIPCData WD 0 OnOff: Process IPC event HWsample 32 WD 0 (Interfaces IOC 0x32 Jacinto 0x31) HINT: Different IPC interface version 50 - we're using 49!!! MMX is running in Emergency IOC Variant:= BOLOTYPE_MIB2_MQB + APPLTYPE_MIB2_MQB SWDL: requestStartUpdate HW index 32, Assist 0 Display: Info3Text Scan metainfo scan for info: 0x540000: ff ff ff ff 92 29 92 29 40 53 57 44 4c 20 56 31 searchInfo 1 Persistance is complete 0x540000 Read version: 3b7 , type 3. 8 (300003b7) Old image[0]: ipl 0, 0x0 0x20000 Old image[1]: ifs-emg 3, 0x20000 0x390d5c Found no transaction image address in metainfo! getTransactionImageAddress from metainfo 0x0 getTransactionImageAddress from update.txt 0x0 Read version: 3b7 , type 3. 8 (300003b7) getTransactionImageAddress from flash 0x0 getTransactionImageAddress from PersistenceFlag 0x540000 Found no transaction image address in metainfo! getTransactionImageAddress from metainfo 0x0 getTransactionImageAddress from update.txt 0x0 Read version: 3b7 , type 3. 8 (300003b7) getTransactionImageAddress from flash 0x0 getTransactionImageAddress from PersistenceFlag 0x540000 TP: copyFilesFromTransactionImageToSharedMemory 11 @0x540000 TP: copyFilesFromTransactionImageToSharedMemory requested /HBpersistence/SWDL/info/MuRegion.txt essential 0 TP: copyFilesFromTransactionImageToSharedMemory requested /HBpersistence/SWDL/info/IgnoreRegionVariant.txt.z essential 0
  2. Opravdu nikdo nemá verzi firmware MHI2_ER_SKG13_P4177_MU1125?
  3. Nevíte, kde by se dal stáhnout firmware MHI2_ER_SKG13_P4177_MU1125, na mibsolution není? Díky.
  4. A není někdo blíže, Ostrava a okolí? Díky.
  5. já jsem právě nahrál nižší verzi MHI2_ER_SKG13_K4524_MU1382 a při té nastal problém. Ještě jsem zkoušel verzi MHI2_ER_SKG13_P4526_MU1440 a to vyhodilo chybu metainfo CRC error viz. obrázek.
  6. Jo a ještě jsem zkoušel SD naformátovat na FAT32, NTFS, exFAT. Taky nic.
  7. Takže jsem použil novou SD kartu (dvě SD) a problém stále stejný. Když se mi to poprvé zastavilo vyběhla hláška na obrázku níže. Když se to spustí znovu přes Emergency Asist Utility pokračuje to podle obrazku dále (erase, program, CRC error). Stáhl jsem znovu i firmware: MHI2_ER_SKG13_K4524_MU1382. Nějaké další řešení? Děkuji.
  8. Zdravím, chtěl jsem provést aktualizaci navigace Columbus SW Train: MHI2_ER_SKG13_P4177. Stáhnul jsem si z mibsolution tento firmware: MHI2_ER_SKG13_K4524_MU1382. Po spuštění se aktualizace zasekla na 80%, po restartu naběhl Emergency Asist Utility a potom hláška Flash CRC error Train MHI2_ER_SKG13_K4524. Nevíte kde by mohl být problém, případně jak dále postupovat? Děkuji.
  9. Chce to použít trochu síly, uchopit plastový kryt, který drží manžetu do svěráku a řadičkou silněji otočit doprava a doleva
