masster
  1. Jaký rozměr má vlákno? Průměr, rozteč.
  2. I see that everyone avoids a direct answer on how to fix a hydraulic tilting mechanism. Why is it so complicated? Someone write a step by step tutorial? It seems that nobody really knows what to do to restore its functionality.
  3. masster odpověděl na wojt's téma v Elektrika
    Thanks for the link. By looking at the datasheet of MAF115, I see it is not compatible with KEFB-842 made by ITT. I will try to explain why I am interested in KEFB-842 datasheet, maybe you could guide me a little. So... my car is 1.3 Felicia LX from 1997, 135 type engine on carburettor. The dashboard is the 'cheap' one with analogue clock. I looked a long time for a dashboard for Felicia GLX on carburettor (yes, they were exported all over the world). But I didn't find one so I bought a second-hand one from a 1.3, 1996 Felicia GLXi (SPi). The only problem I have is about the signal feed for the tachometer. SPi Felicia is using 5V pulses (TTL) from the ECU, one pulse / revolution (I guess). Felicia on carburettor gets the signal feed for the tachometer from pin 1 of the ignition coil. This means 12V pulses and two pulses / revolution. See the difference? I don't have enough information to know what to do next... that is why I need help.
  4. masster odpověděl na masster's téma v Elektrika
    Deska plošných spojů pro Felicia (na přístrojové desce), není tak jednoduché. Otáčkoměr, obvod pro palivoměru, obvody pro analogové a digitální hodiny, obvod pro teploměrem. Nejedná se o jednoduché spojení mezi třemi konektory. V případě, že někdo má schémat, prosím po nich. Děkuju. ======================== The PCB for Felicia (the instrument cluster) is not as simple as you describe it. The tachometer, the circuit for the fuel gauge, the circuits for the analogue and/or digital clock, the circuit for the temperature gauge. All these are not simple connections between three connectors. In case anyone has the schematic diagrams, please post them. It means a lot to me. Thank you.
  5. masster odpověděl na wojt's téma v Elektrika
    Je MAF115 ekvivalentní s KEFB-842 (ITT)? Vzhledem k tomu KEFB-842 je na každé desky s plošnými spoji pro Felicia. Hledám katalogové listy na obou integrovaných obvodů. Můžete po nějaké platné odkazy, prosím? Nemohl jsem najít nikde v manuálu k KEFB-842, a to je moje poslední šance. Prosím omluvte mě jestli má zpráva má pravopisu nebo gramatické chyby. Nejsem Czech.and asi nesmím psát v angličtině.
  6. masster zveřejnil téma v Elektrika
    Můžete mi pomoci najít schémata pro PCB desce, prosím?
  7. Nechápu, jak cestující v zadní dostat teplo z topné jednotky. Já vím, že je kanál na podlahu pod centrálního sloupu, ale nevidím žádnou díru v blízkosti nohou spolujezdce.
