Toto je výpis z diagnostiky....
Monday,28,March,2016,19:07:58:62939
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 56 62 6C 72
VIN: TMBDS21Z972023084 Mileage: 237180km/147376miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LB HW: 03G 906 021 LB
Component: R4 1,9L EDC G000SG 8501
Revision: --H02--- Serial number: SKZ7Z0F3693052
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 6ADB2423458A32489EF
1 Fault Found:
005746 - Coolant Fan Control 1
P1672 - 000 - Open or Short to Ground
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 237187 km
Time Indication: 0
Date: 2000.00.00
Time: 18:49:03
Freeze Frame:
RPM: 798 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.44 V
Bin. Bits: 00101100
Temperature: 30.6°C
Duty Cycle: 9.7 %
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
VCID: 73E539471240F3802D9
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 AC HW: 1Z0 907 044 AC
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 77FD0D5706389FA0111
1 Fault Found:
00457 - Control Module for Network (J519)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004142026
Coding: B5008E011004140041110D000000000000097F075C
Shop #: WSC 73430 790 12345
VCID: 2B55E1278AF0EB40A59
Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer SK351 012 0401
Coding: 00063477
Shop #: WSC 73430
1 Fault Found:
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 191
Mileage: 237187 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 14.25 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q2 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD0KNRYO
Coding: 0020786
VCID: 3D71DF7F648475F00BD
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenksäulenmodul 034 0070
Coding: 0000042
Shop #: WSC 75627 790 00000
VCID: 76E300530132E6A80A7
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 842 H HW: 1Z0 920 842 H
Component: KOMBIINSTRUMENT VD1 1614
Revision: V0004000 Serial number: SKZ7Z0F3693052
Coding: 0010103
Shop #: WSC 80093 222 69422
VCID: 3C77D27B7F9E7CF83C3
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 260907F2001934
Coding: E9807F064042031302
VCID: 306FF64BA3D6889890B
1 Fault Found:
02873 - Control Module for Back-Up Camera (J772)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 191
Mileage: 237187 km
Time Indication: 0
Date: 2000.00.00
Time: 18:50:10
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1614
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Mileage: 212141 km
Time Indication: 0
Date: 2000.00.00
Time: 00:50:07
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 3T0 035 192 D HW: 3T0 035 192 D
Component: RNS315-EU H35 0263
Serial number: SKZAZ2L9227566
Coding: 040104510401000000000007
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS_SK35.rod
VCID: 2F6DF53776E89760891
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_0038 0038
2 Faults Found:
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 237187 km
Date: 2000.00.00
Time: 18:50:30
1048665 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 237187 km
Date: 2000.00.00
Time: 18:50:35
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0165
Coding: 0000118
VCID: F4E7BA5B974E74B8B43
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.068 H07 1806
Shop #: WSC 02069 000 90108
VCID: 3467FA5B57CEB4B8F43
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CR HW: 1K0 959 433 CR
Component: KSG PQ35 G2 044 0203
Revision: 00044000 Serial number: 00000000000000
Coding: 80801A485103007F3F04850500084F01803C00
VCID: 820BEC83DDFA4A08B6F
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
2 Faults Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 230
Mileage: 237150 km
Time Indication: 0
Date: 2000.00.00
Time: 14:12:23
Freeze Frame:
Fault Status: 01101101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 191
Mileage: 237187 km
Time Indication: 0
Date: 2000.00.00
Time: 18:49:30
Address 4F: Centr. Electr. II (J533) Labels: 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 1K0 907 951
Coding: 00000000
VCID: E6C3D013119296283A7
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Component: Tuer-SG 024 2345
Coding: 0000246
VCID: 377DCD5746B85FA0D11
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 E
Component: Tuer-SG 021 2405
Coding: 0000144
VCID: 326BFC43ADDABA88E6F
Address 6C: Back-up Cam.
Cannot be reached
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 E
Coding: 0000144
VCID: 3365F94752C0B380ED9
End ---------------------------------------------------------------------
