Publikováno Únor 13, 200718 r chlapy potrebujem poradit ohladom tohoto zosilovaca vypada mat celkom gut parametre...neviete o nom nieco ? chcem napojit ESK 163S + DCX690 a casom nejaky subac 100W RMS MAX power 2 x 190W RMS power at 4 ohms 4 x 65W + 1 x 130W RMS power at 2 ohms 4 x 95W + 1 x 180W RMS power in bridged mode at 4 ohms 2 x 190W + 1 x 150W TDH (all channels driven) 0,02% Frequency response 10 Hz – 30 KHz (+/-3,0 dB) Signal / noise ratio 90 dB Input signal 100 mV a 10 V Low pass filter Continuous variable Low pass frequency range 5ch 40 Hz - 240 Hz High pass filter Continuous variable High pass frequency range 1ch-4ch 40 Hz - 240 Hz Bass boost (0 a +12 dB) 45 Hz V-Bass Dimensions (W x H x D) mm 267 x 48,5 x 450 Upraveno Únor 13, 200718 r od TiGeRZ
