jak odpudit zlodeje
O.v.i.
Ako to mam stiahnut alebo spustit???? :huh:
Pokud ti to nepise cervene
All download slots (500) assigned to your country (Czech Republic) are in use.
Please try again later.
tak pockas az ubehne bezici cas a zavres to okno co se ti spusti na tom case. Potom uy jenom Click here to download a fertig
je to volaaké pomrdané, pokouším se to sosnout asi 2dny a furt obsazené :ph34r:
Do prdele, já to nestáhnu. Hlásí mi to chujovinu.
Your IP address (62.240.163.14) is currently downloading a 200131737 byte RAR file.
Please finish this download before starting another one. If you have just recently canceled this download, try again in a few minutes, as the download connection may not have terminated yet.
If 62.240.163.14 is not your IP address, you may be sharing a proxy or NAT gateway with other Megaupload users. If you have configured an HTTP proxy in your browser, disable it and try again. If you don't have a proxy configured, using a different download port may bypass your ISP's proxy. If you see your real IP address listed below, please select it, then try your download again:
(Port 80)
(Port 800)
(Port 1723)
For unlimited parallel high-speed downloading, you may also sign up for a Megaupload Premium Membership, which includes a number of additional benefits:
