Riadiaca jednotka okna sofer
Potreboval by som poradit. Zatiekla mi riadiaca jednotka okna na soferovej strane. Ako nakodujem novu? Dakujem VAG 8.05
Crash data 1J0 909 603 AS
Neviem kde robim chybu ale mi to nejde prepisat. Nestretol sa s takymto problemom niekto? Checking adapter ... Adapter version : Airbag 3.0 Please wait before open controller ... Please waitting to open controller... ... Open controller OK! Protocol : KWP1281 Reading part number ... Sending Ack ... Reading component ... Sending Ack ... Reading ECU component ... Send Ack to ECU ... Please waitting for Coding and WSC ... Read ECU information OK! Please watting for read ECU version ... ... ECU is supported ! Login to system ... Login OK! Start write EEPROM ... Addr: 0000H Data: FFH Addr: 0001H Data: 82H Addr: 0002H Data: A6H Addr: 0003H Data: 7AH Addr: 0004H Data: F8H Addr: 0005H Data: 00H Addr: 0006H Data: FFH Addr: 0007H Data: FFH Addr: 0008H Data: FFH Addr: 0009H Data: FFH Addr: 000AH Data: FFH Addr: 000BH Data: FFH Addr: 000CH Data: FFH Addr: 000DH Data: FFH Write FAIL!
1J0909603AS SIEMENS,Octavia,Dva airbagy
Daju sa zmazat z tejto jednotky crash data? Dakujem Coding_16723_WSC31480.zip
Airbag 1J0 909 608
Reset airbag
Akym kablom by sa dali vycitat udaje z RJ? Alebo to nieje take jednoduche? wv.bmp
Snimac rychlosti
No je to riesenie ale neda sa to robit kazdy den. Ale aj tak dik. Ked je to z abs tak len cez PC.
Snimac rychlosti
Prave ze potrebujem pripisat
Snimac rychlosti
Neviete poradit kde sa na oct II nachadza snimac rychlosti. V ktorych mieatach. Dik
Elektrika Octavia s klimatronom a bez
Neviete niekto poradit ci sa da prehodit elektrika do octavie 99 1.9TDI 81kW s palubnym a s klimatronom z octavie bez palub a s manualnou klimou. Dik
Loposino
