irfant
  1. I strongly recommend claying before polishing or waxing. It has tremendous effect on surface roughness. After few passes you can feel the cleaned surface on your finger tips. You can easly find on E-bay etc. Don't forget to order a clay lubricant (like Meguiars Quick Detailer) together with a clay bar.
  2. Claying is very very easy... Just mist with the spray than go with clay bar... Thoroughly wash and dry your vehicle. (To save time, many professionals clay the paint after the final rinse, while it's still wet). Cut your clay bar into halves or thirds, so if you accidentally drop the bar (it will happen) you'll only lose a small portion. If a clay bar is dropped on the ground, it is contaminated and must be thrown away. Always work on the vehicle in the shade, and out of the wind to save on lubricant. Spray the lubricant over a 2' x 2' area. Tuck the clay bar tucked into the palm of your hand and glide it across the lubricant. I prefer back and forth movements to keep track of finished areas. If you are claying the entire vehicle, start from the top and work your way down to the lower sections. Use one side of the clay until it stops picking up the contaminants, and then turn it over to the fresh side. When the second side is full of contaminants, you can knead the clay to produce two fresh surfaces. The average clay bar should clean 5 to 10 cars, depending on the amount of contamination. Continue around the car until all painted surfaces have been clayed. You can also clay your glass, chrome, metal pieces and coated wheels. Your car should now be smooth and ready to be polished and waxed. Clay removes: Tree sap mist Paint overspray Industrial fallout Hard water deposits Diesel fuel exhausts Rubber particles from other cars Insect droppings Bug remains And much more!
  3. Foam wash + engine bay cleaning + claying + Swirl Removing (Turtle Wax ) + Turtle Wax Nano Tech wax application (I use Einhell orbital buffer, a cheap one (500 rpm max, 120 watt) And the story looks like...
  4. irfant odpověděl na fabiavrs's téma v Fabia
    Hi Mike, Try this... Super Skoda web site
  5. irfant odpověděl na irfant's téma v Roomster
    Silver color is my favorite, because even the car is dirty you can not easily notice the dirt etc. It looks ever-clean... Scratches are not visible at the first look...
  6. Thank you, the silver line looks great... Actually I tought to do more silver, but black areas make a good contrast on car. For example spraying the front grill don't look so good like this...
  7. Antikorózní ocel výfuk extra...
  8. irfant odpověděl na Adam007's téma v Fabia
    WOW! Sounds great!
  9. English only...
  10. irfant odpověděl na M!NGO's téma v Octavia
    Car looks great! Resembles to VW Bora from front...
  11. irfant odpověděl na GRZYBXTREME's téma v Fabia
    Hello and Welcome Piter...
  12. Thank you! Cheap and easy application...
  13. Milotec has this... This Sunday I've applied spray paint to the foglight frames. Ducktaped all the surface that I don't want to smear. Here is the result...
  14. irfant odpověděl na RoLi's téma v Fabia
    Try this http://www.superskoda.com
