Climatronic - závady, problémy
Mam takyto problem s climatronicom a poviem vam...idem dnes autom zo ziliny a ked mam stlaceny econ tak mi fuka trosku vlazny vzduch ale ked ho vypnem tak mi za par sekund prestanu fukat fukare a iba to huci ako keby pod kaslikom spolujazdca....a ked zapnem econ tak mi chvilku fuka studeny vzduch z klimy a za par sekund sa zas otepli a fuka teplejsi vzduch....minuly rok mi klima fungovala perfektne a koncom leta som ju daval cistit a plnit....vie mi niekto pomoct? Dakujem
Pri osvetleni noh susti radio
Toto je výpis z diagnostiky.... Monday,28,March,2016,19:07:58:62939 VCDS Version: Release 11.11.6 (x64) Data version: 20121223 Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 4F 52 56 62 6C 72 VIN: TMBDS21Z972023084 Mileage: 237180km/147376miles 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 37-Navigation -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: Cannot be reached 1100 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.lbl Part No SW: 03G 906 021 LB HW: 03G 906 021 LB Component: R4 1,9L EDC G000SG 8501 Revision: --H02--- Serial number: SKZ7Z0F3693052 Coding: 0000071 Shop #: WSC 73430 790 00000 VCID: 6ADB2423458A32489EF 1 Fault Found: 005746 - Coolant Fan Control 1 P1672 - 000 - Open or Short to Ground Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 1 Mileage: 237187 km Time Indication: 0 Date: 2000.00.00 Time: 18:49:03 Freeze Frame: RPM: 798 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 14.44 V Bin. Bits: 00101100 Temperature: 30.6°C Duty Cycle: 9.7 % Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0021121 Shop #: WSC 73430 790 00000 VCID: 73E539471240F3802D9 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1Z0 907 044 AC HW: 1Z0 907 044 AC Component: ClimatronicPQ35 120 0600 Revision: 00120022 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 77FD0D5706389FA0111 1 Fault Found: 00457 - Control Module for Network (J519) 013 - Check DTC Memory ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000004142026 Coding: B5008E011004140041110D000000000000097F075C Shop #: WSC 73430 790 12345 VCID: 2B55E1278AF0EB40A59 Subsystem 1 - Part No: 1Z1 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SK351 012 0401 Coding: 00063477 Shop #: WSC 73430 1 Fault Found: 02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 5 Fault Frequency: 1 Reset counter: 191 Mileage: 237187 km Time Indication: 0 Freeze Frame: ON Voltage: 14.25 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: Q2 AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD0KNRYO Coding: 0020786 Shop #: WSC 73430 790 00000 VCID: 3D71DF7F648475F00BD No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF Component: Lenksäulenmodul 034 0070 Coding: 0000042 Shop #: WSC 75627 790 00000 VCID: 76E300530132E6A80A7 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 842 H HW: 1Z0 920 842 H Component: KOMBIINSTRUMENT VD1 1614 Revision: V0004000 Serial number: SKZ7Z0F3693052 Coding: 0010103 Shop #: WSC 80093 222 69422 VCID: 3C77D27B7F9E7CF83C3 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 260907F2001934 Coding: E9807F064042031302 Shop #: WSC 73430 790 12345 VCID: 306FF64BA3D6889890B 1 Fault Found: 02873 - Control Module for Back-Up Camera (J772) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 191 Mileage: 237187 km Time Indication: 0 Date: 2000.00.00 Time: 18:50:10 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 842 H HW: 1Z0 920 842 H Component: IMMO VD1 1614 Revision: V0004000 Serial number: SKZ7Z0F3693052 Shop #: WSC 00000 000 00000 VCID: 3C77D27B7F9E7CF83C3 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Mileage: 212141 km Time Indication: 0 Date: 2000.00.00 Time: 00:50:07 ------------------------------------------------------------------------------- Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb Part No SW: 3T0 035 192 D HW: 3T0 035 192 D Component: RNS315-EU H35 0263 Serial number: SKZAZ2L9227566 Coding: 040104510401000000000007 Shop #: WSC 80093 222 69422 ASAM Dataset: EV_RNS315EUV2UDS A01004 ROD: EV_RNS315EUV2UDS_SK35.rod VCID: 2F6DF53776E89760891 Data medium: Subsystem 1 - Part No: 3AA 919 866 Component: EUR_W_0038 0038 2 Faults Found: 1048629 - Aux IN Socket B1104 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 191 Mileage: 237187 km Date: 2000.00.00 Time: 18:50:30 1048665 - Function Restricted due to Missing Message(s) U1111 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 191 Mileage: 237187 km Date: 2000.00.00 Time: 18:50:35 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl Part No: 1T0 959 701 Component: Tuersteuergeraet 09 0165 Coding: 0000118 Shop #: WSC 73430 790 00000 VCID: F4E7BA5B974E74B8B43 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K1 909 144 L Component: EPS_ZFLS Kl.068 H07 1806 Shop #: WSC 02069 000 90108 VCID: 3467FA5B57CEB4B8F43 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 CR HW: 1K0 959 433 CR Component: KSG PQ35 G2 044 0203 Revision: 00044000 Serial number: 00000000000000 Coding: 80801A485103007F3F04850500084F01803C00 Shop #: WSC 73430 790 12345 VCID: 820BEC83DDFA4A08B6F Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted 2 Faults Found: 00457 - Control Module for Network (J519) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 230 Mileage: 237150 km Time Indication: 0 Date: 2000.00.00 Time: 14:12:23 00457 - Control Module for Network (J519) 013 - Check DTC Memory Freeze Frame: Fault Status: 01101101 Fault Priority: 4 Fault Frequency: 1 Reset counter: 191 Mileage: 237187 km Time Indication: 0 Date: 2000.00.00 Time: 18:49:30 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II (J533) Labels: 1K0-907-532.clb Part No SW: 1K0 907 532 HW: 1K0 907 951 Component: J533 Gateway H07 0052 Revision: H07 01 Serial number: 260907F2001934 Coding: 00000000 Shop #: WSC 73430 790 12345 VCID: E6C3D013119296283A7 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1T0 959 702 B Component: Tuer-SG 024 2345 Coding: 0000246 Shop #: WSC 73430 790 00000 VCID: 377DCD5746B85FA0D11 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 E Component: Tuer-SG 021 2405 Coding: 0000144 Shop #: WSC 73430 790 00000 VCID: 326BFC43ADDABA88E6F No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Cannot be reached ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 E Component: Tuer-SG 021 2405 Coding: 0000144 Shop #: WSC 73430 790 00000 VCID: 3365F94752C0B380ED9 No fault code found. End ---------------------------------------------------------------------
Takže k tomu svetielku čo?
Pozeral som co je ten feritovy filter a tym myslis skusit obalit ten konektor? A zacalo to robit az po montazi...aj ked vypnem svetla tak radio ide normalne ale ked ich zapnem tak hned zacne sustat.
Vobec netusim co to je...mohol by si mi to prosim vysvetlit? Ked tak to poviem tomu kamaratovy ak by s tym vedel nieco objednat....este s tym je taky problem ze mi stredovy panel co je klimatronic a radio svieti slabsie ako ostatne casti palubovky... myslis ze by aj nato pomohol ten filter?
Led...objednane z aliexpresu
Kamarat mi domontoval osvetlenie noh ale ked mi svieti tak susti radio....vie mi s tym niekto poradit?
johny311
