Vloženo
Zdravim vsetkych,
sory ak tu take vlakno je ale som v koncoch a neviem co dalej tak by som poprosil touto cestou o radu.
Dnes som odpojil baterku zhruba na cely den na aute: Fabia 1,9TDI r.v.2001 z dovodu vymeny serva a po opetovnom napojeni baterky auto vobec nejde nastartovat a VAG stale dava tieto chyby:
Monday,21,May,2012,17:59:57:55371
VAG-COM Version: Release 704.1
Data version: 20070422
Chassis Type: 6Y - Skoda Fabia
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 56 76
Address 01: Engine Labels: 038-906-019-100.LBL
Part No: 038 906 019 AF
Component: 1,9l R4 EDC G710SG 1056
Coding: 00002
Shop #: WSC 13765
TMBMS26Y613108143 SKZ7Z0Y0583209
3 Faults Found:
17977 - Cruise Control Switch (E45): Implausible Signal
P1569 - 35-00 - -
18056 - Powertrain Data Bus: Failure
P1648 - 35-10 - - - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 - -
Readiness: 0 0 X X X
Address 08: Auto HVAC Labels: None
Part No: 6Y0 820 045
Component: Klimaanlage X0760
No fault code found.
Address 09: Cent. Elect. Labels: None
Part No: 6Q1 937 049
Component: BORDNETZ-SG. 1S30
Coding: 09402
Shop #: WSC 13765
6 Faults Found:
01309 - Power Steering Control Module (J500)
49-00 - No Communications
01321 - Control Module for Airbags (J234)
01317 - Control Module in Instrument Cluster (J285)
01316 - ABS Control Module
01314 - Engine Control Module
01312 - Powertrain Data Bus
37-00 - Faulty
Address 19: CAN Gateway Labels: 6N0-909-901.LBL
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S30
Coding: 00014
Shop #: WSC 13765
6 Faults Found:
37-00 - Faulty
Address 46: Central Conv. Labels: 6Q0-959-433.LBL
Part No: 6Q0 959 433 C
Component: 07 Komfortgerát 0002
Coding: 00259
Shop #: WSC 04938
Part No: 6Q1959801A
Component: 05 Tőrsteuer.FS TFK 0003
Part No: 6Q1959802
Component: 07 Tőrsteuer.BF TFK 0002
Part No: 6Q0959811
Component: 07 Tőrsteuer.HL TFK 0002
Part No: 6Q0959812
Component: 07 Tőrsteuer.HR TFK 0002
1 Fault Found:
79-00 - Please Check Fault Codes
End --------------------------------------------------------------------------------------------------
S elektrikou som vobec nic neporabal okrem odpojenia a napojenia noveho serva.
PROSIM PROSIM PROSIM neviete v com je chyba???
Vdaka za akukolvek odpoved.
