HVIEZDICA S VALCEKMI
doBRY DEN MAM PROBLEM VYMENIL SOM NA SVOJEJ 1,4 VSETKY CAPY TLMICE PRUZINY A STALE MI BUCHA NIECO V PREDU KED SOM ZDVIHOL AUTO TAK KED HYBEM POLOOSOU TAK V NEJ CUKA OD PREVODOVKY. MYSLIM SI ZE TAM MOZE BYT VYBITA TA HVIEZDICA S VALCEKMI MATE NIEKTO SKUSENOST. AUTO MA NAJAZDENYCH 150000KM A PRI ROZBEHU TO HADZE A DOST AJ BUCHA CI PRI ROVNEJ JAZDE CI PRI ZATACANI. vid obrazok cast vnutorneho homokinetickeho klbu
a stale vrzga
ked som menil tlmice a pruziny aj axialne som vymenil komplet aj dorazy
a stale vrzga
DOBRY DEN POTREBUJEM RADU NA MOJEJ FABKE SOM VYMENIL KOMPLET TLMICE PRUZINY LOZISKA VSETKY CAPY SILENBLOK RAMENA A KED OTACAM KOLESOM NA MIESTE ALEBO ZA JAZDY POCUT TAKE GUMENE SKRIPANIE AJ BUCHNUT SEM TAM .DAL SOM DOLU UZ AJ GUMY Z TYCE RIADENIA A NAMAZAL ICH SILIKONOM A STALE .STABILIZATORY SU NOVE . NEVIEM VAZNE S KADE TO IDENEMATE PODOBNU SKUSENOST.
EMISNA KONTROLA ?
No filter je vymeneny aj retaz je menena a ako sa da vycistit skrtiaca doma neviete poradit tak aby som ju nerozladil??
EMISNA KONTROLA ?
diky za radu mam manual tak som to aj nasiel. PROBLEM JE ALE ASI INDE BOL SOM NA POCITACI A LAMBDA JE DOBRA MERAL AJ KATALIZATOR ZE TEN TIEZ TAKZE NEVIEM CO TO MOZE BYT KED TIE EMISIE TANKUJEM SHELL.ESTE SOM ROZMYSLAL ZE PODPALENY VYFUKOVY VENTIL ALE TO BY ASI POCITAC UKAZAL.POCITAC MI NIC ANI NEVYPISUJE ZE MAM PROBLEM???CIL COOO
EMISNA KONTROLA ?
ESTE NEVIETE PROSIM PRESNE OBJEDNAVAJUCE CISLO ORIGINALU ALEBO TEJ BOSHACKEJ LAMBDA SONDY?? AKU MAM TEDA OBJEDNAT?? 1,4MPI 44KW AZE MOTOR EU2
EMISNA KONTROLA ?
ANO JA MAM NORMU EUR 2 CIZE JEDNA LAMDA PRED KATAL. A CHCEM TU OD BOSCH U NAS ORIGO STOJI 150eUR A TIE BOSCH CCA 90 ZEVRAJ SU KVALITNE .ZAUJIMA MA CI MOZE NEFUNKCNOST POSKODIT AJ KATALIZATOR A CI TREBA PO VYMENE LAMDY AJ NASTAVIT RIADIACU JEDNOTKU??? DIKY VAM ZA RADU
EMISNA KONTROLA ?
DNES SOM BOL NA EMISNEJ (SKODA FABIA HB 1,4 44KW RV.2000) A POVEDALI MI TAM ZE MAM VSETKO V CERVENOM ZE MAM CHYBNU LAMBDA SONDU. CHCEM SA INFORMOVAT CO MAM ROBIT (POSTUP PRAC)TO AUTO TROSKU VIAC PAPA A MENEJ TAHA AKO OTCOVA TA ISTA FABIA ANE NIC MI NEVYPISUJE PALUBKA. AK KUPIM NOVU LAMBDA SONDU DA SA DOMA VYMENIT LEBO NIE JE TAM NIC ZVLASTNE LEN NAKRUTIT A ZAPOJIT CI????? MYSLIM ZE BY TO NEMAL BYT PROBLEM. TREBA TAM ESTE NIECO NASTAVOVAT ??AKO OVERIM ZE PRECUJE NOVA SPRAVNE A STARA BOLA ZLA??? ALEBO DA SA ZISTIT ZE TA STARA JE VAZNE ZLA NEJAKO?? NEMOZE BYT POSKODENY KATALIZATOR??DIKY ZA RADU ??
zadne tlmice
Ja som to videl na vela fabkach maju to otrhnute to hrdlo co je odtrhnute od toho plastoveho zvonu pri kolese .asi to pokusim sam spravit ten postup nevies kde bol ??na ktorej stranke alebo teme
zadne tlmice
Dakujem presne toto skusim to .kolko stoji ta krytka??
zadne tlmice
Prosim vas aj vy mate odtrhnutu na zadnom tlmici tu krytku od toho plastu nachadza sa nad zadnym kolesom?? da sa to vymenit uz 2 krat som ju skusal prilepit naspet ??
zblbnutie elektriky.
Heloo ja mam taky problem ze mi zacali blikat svetla ale velmi jemne stahovat ich a niekedy sa mi rozsvieti servo . kabel mam rozmotany a bol, som na kontrole ze to tam je v poriadku skablom co by to mohlo byt neviem si rady a servise vzdy tocia o niecom inom .
Čidlo spiatočky
No ja som ho menil sam su dva druhy cidla s hrubsim a tensim zavytom kupil som original 200SK a 10 minut roboty doma v garazi vsetko facha
Čidlo spiatočky
Heloo bol som nemenovanom znackovom servise a povedal som ze mam vadne cidlo cuvania ze vymenit prisiel som o par hodin a on ze je kabelaz zla ze 3000 to bude stat tak som isiel domov zmeral kabel kupil cidlo 119 sk vymena 10 min asi taky je u nas servis ze Skoda a vsetko je v poriadku
ŠROUB NA VYPOUŠTĚNI OLEJE Z MOTORU
no ja som mal to iste menil som olej tesnili olejovu vanu a zle dotiahli srob vypustny pod nim je podlozka treba sa pozret pod auto ja som to dotiahol a uz je sucho ale olejovu nikdy nepretesnia aby nemokvala trochu to kazde auto ma ktore nie to nema olej v sebe
Yves
