Columbus s Android 2.3/4.1+ plná podpora CAN za super cenu!
Ahoj tak jsem se rozhodl pro koupy podělit o zkusenosti ... cekam az prijde pak dam vedit zatim jen odkazy
http://www.aliexpress.com/item/New-1080P-pure-Android-Capacitive-Screen-Car-DVD-for-VW-SKODA-512MB-memory-8GB-storge-Space/808790362.html
Podpora aut:
Skoda:
Fabia(2009 - )
Octavia(2009 - )
Superb(2008 - )
Roomster(2006 - )
Viz video doporučuji schlédnout
http://www.youtube.com/watch?v=GLAVEjallzE
Popis:
Android 2.3 system
Fresh unique UI interface
CPU: FREESCALE CORTEX A8,1GHz frequency
Built in 8GB iNAND MLC Flash RAM
Quick response after lighting the car: within 1 sec for starting, within 2 secs for sound, within 3 secs for rearview, within 15 secs for operation
Support 3G/ WIFI internet surfing
Support thousands of softwares downloading from Android market
Core board digital RGB888 direct drive, higher definition and clearer display
Touch screen control with dynamic graphic user interface
Support multi-resolution,UXGA@60HZ1600*1200 max, support larger screens above 10inch car DVD, clearer than resolution 800*480 with the same fluence
Integrated GPU with hardwares support 2D/3D speeding, supports OpenGLES2.0 and OpenVG1.1, 1080P decode
Built-in navigation with 3D map (map in SD card)
Support DVB-T,ATSC, Analog TV, Compatible with PAL/NTSC/SECAM format
Video support: wmv (VC1 codec),   .avi (H.264, MPEG4, MJPEG, Xvid, WMV),  .mp4 (H.263, H.264, MPEG4 codec),  .mpg (MPEG-2 codec),  .m4v (H.264, MPEG4)
Support HD 2D & 3D games
Support SD/MMC/SDHC SD ports, SDHC supports max 32G
Bluetooth supports all brands cellphones,phonebook input,music playback
Upraveno od jtfcobra
Z videa to vypada hodne dobre. Vkusny design, svizny software... Jeste jde o kvalitu zvuku a celkove o kvalitu zpracovani. To se z videa zjistit neda. Potom dej urcite vedet.  :kol-47:
Ted musim dat PRODAT Columbuse ... ALE libi se mi ze se komunikuje z parkovakama klimou ... volantem to je fakt Super ....
Jo, to je bomba. (Zrovna klimu mam vyplou, prijde mi to k nicemu, ale proti gustu...)
Jelikož JSEM programator Android apps Tak nevidim v. problém Si se přizpůsobit podle svého ...
O jaký že to jde zkušenosti když to ještě nemáš? Aspoň shlédnu to video. btw chlubící se programátor co dělá hrubky a ještě k tomu na štědrý den
Upraveno od šulda
Děkuji omlouvám se že jsem se rozčílil.....fakt chci jen ukázat jiné možnosti...
Brzdi, přihlouplá poznámka byla odstraněna. Osobní útoky tady nebudu trpět! To si vyřizujte přes SZ.
Taky se omlouvám za rejpnutí. Rád se podívám na recenzi od člověka co má s danou věcí zkušenosti ale pokud něco nemám tak ji neudělám, video a parametry najdu na netu. Takhle to zatím působí jako posthunting a do programátora který to "takto" o sobě napíše se snad nedá netrefit. Další případnou reakci už opravdu jedině přes SZ, toto jen proto abych nebyl hned vhozen do nějakého pytle ;)
V pohodě...
tak pak dej hlavně vědět, protože kolumbus to je hrozně marnej stroj...
myslíš že tam pojede rozjet TV tuner na tomhle droidovi?
No co jsem koukal jde tam rozjet:
- 3G Modem
- TV USB DVB-T
A hlavně jde o tu rychlost proti COLUMBUSU ten je fakt lenivej
no uvidime zda to bude lepší zatím podle youtube videi to vypada dobře...
jaký si měl SW na kolumbovi? ta poslední 5238 to trošku zrychlila, ale je to prostě hrůza...
tak to by tam měl jít možná rozjet i origoš TV tuner co mam v autě na zkušebku...
jj 5238 mám taky malinko to zrychlila a hlavně to neumí vůbec nic .... za 40000 Kč?No trochu mimo realitu
TV tam bude podle mně jen ten co jde pod Android. Origo asi ne...
Hlavně co se mi u androidu líbí je to že si můžeš doinstalovat co chceš a přizpůsobit si to (např pustit si AVI z SD karty u columba uplně mimo svět)
Přehrávat jeden update druhým způsobí vždy pomalejší a pomalejší navigaci(Columbuse). Problém všech těchto zařízeních z Číny je kvalita...kdo to měl, vždy po roce na ní něco řešit(odcházející dispej, občasné vypínání - teplo a zima tomu dá zabrat, kvalitu FM tuneru, atd.) Mě osodně zajímá zda už ví soudruzi v Číně co je to RDS(zda si to stále nepletou s vyhledáním jiné silné dostupné stanice).
Upraveno od ferda25
No jsem taky na to zvědavý....na kvalitu ....a výdrž....ale když to vydrží rok nebo dva tak je OK
RDS by mělo být OK
ty dřívější čínské měly divné OS....něco jako má COLUMBUS....
Vypadá to ze v CR nikdo zatím tuto navigaci nema tak uvidime...
Jo za rok se uvidí víc. Do té doby budeš testovací kus...To RDS otestuj, neznám Čínu, která by ho uměla jak má.
Na to jak to bude fungovat jsem zvědav, osobně se dost divím že tyhle stroje nejsou víc rozšířené, není na nich nic zázračně složitého a všechny tovární multimedia a infotainmenty strčej do kapsy. Z Číny se jich dá například na dx.com objednat hafo, ale asi bych se stejně bál. Pak je tu ještě možnost značka Zenec, to je Švýcarská firma a má i českého ofiko dealera http://www.zenec-praha.cz/autohifishop/eshop/1-1-Multimedialni-stanice-s-GPS/1-2-OEM-E-GO-naviceivery Určitě sem napiš až to budeš mít v autě, jak to funguje a co to umí, kdyby jsi natočil později i video tak by to bylo super ;) Držím palce...
Upraveno od ic.sniper
Za kolik budeš prodávat columbuse?
jj jen jeste nevim za kolik...
tak kdyby byla nějaká zajímavá a rozumná cena měl bych vážný zájem..
Navrhni cenu do zpravy....
zprava poslána
