Ahojte mal som "koliziu s diviakmy" auto bolo s predu zdemolované.
Naraznik , blatniky , kapota, svetla, boli porušene Airbagy nebuchly.Ale vyskocila chyba airbagu kod chyby 9682162.(Kolizna brzda) , front assistent nebol zničeny zver narazila s boku takže sa ani neaktivoval Front Assisten.No auto som dal dokopy len ma zaujíma či mam íst do škody aby to pozreli oni alebo sa to dá nejak anulovat? že auto už je ok.Dakujem za odpoved.ABS nehlási chybu.Park Assistent taktiež hlasil ale predne senzori nemám tak som sa čudoval.
aturday,19,December,2020,14:35:41:16946
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: TMBEN6NJ7GZ046250   License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 05 09 10 13 15 17 19 2B 44 5F
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H22 9086
   Revision: R4H22---
   Coding: 01190032232415080000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ECM12TFS01140E906027BC 001009
   ROD: N/A
   VCID: 66C3D0AE9925FF760B-8032
No ASAM data for: "EV_ECM12TFS01140E906027BC" (SK26)
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08501029150714
   Coding: 41F5487D492733C60916106E0051821292CC9008000DCBF98F00
   Shop #: WSC 13765 031 00063
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 377D4DEA8E0FB6FE60-8062
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0604
   Revision: 00021000    Serial number: 0373359662
   Coding: 000F0F
   Shop #: WSC 13765 790 00063
   ASAM Dataset: EV_KessyHellaQMBAB 002011
   ROD: N/A
   VCID: 3A7B54DEBD1DAB969F-806E
No ASAM data for: "EV_KessyHellaQMBAB" (SK26)
1 Fault Found:
65813 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 4
                    Reset counter: 253
                    Mileage: 55198 km
                    Date: 2020.12.11
                    Time: 04:25:27
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-090-V1.clb
   Part No SW: 6C0 937 090 D    HW: 6C0 937 090
   Component: BCM PQ26 HiKR H08 0094
   Serial number: 001388013566
   Coding: 0C01085042150AFB43804000402703080800D900D30A3500000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006_SK25.rod
   VCID: 29599B9248BB100EE6-807C
   Rain Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S4Y15M07D24H12M31S59
   Coding: 00185E
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000001653080
   Coding: 011200
   Relative Air Humidity Interior Sender:
1 Fault Found:
558100 - Databus
          U1123 00 [009] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 55198 km
                    Date: 2020.12.12
                    Time: 02:40:27
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0048
   Revision: --------    Serial number: 39231520101792
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   ROD: EV_EPHVA14AU3700000_002_SK37.rod
Address 13: Auto Dist. Reg (J428)       Labels:. 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 22061503210370
   Coding: 00000000FE0339
   ASAM Dataset: EV_ACMCRRBoschVW372 001016
   ROD: N/A
No ASAM data for: "EV_ACMCRRBoschVW372" (SK26)
1 Fault Found:
0080 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 55198 km
                    Date: 2020.12.11
                    Time: 04:24:46
Address 15: Airbags (J234)       Labels:. 6C0-959-655.clb
   Part No SW: 6C0 959 655 F    HW: 6C0 959 655 F
   Component: VW20Airbag733 001 0360
   Revision: --------    Serial number: 003RJ004DUJT
   Coding: 88CCC000000000005C5400CF000800000000
   ASAM Dataset: EV_AirbvAW20BPAVW26X 001001
   ROD: N/A
   VCID: 366340EE89054FF67B-8062
   Subsystem 1 - Part No SW: -----------    HW: 410 822 306 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00B31B55C11E30I
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 410 822 306 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00AD1B7F3F243F8
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 442 151 807 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A51B6A7628028
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 442 151 807 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A51B6A760C22D
   Coding: 2D2D2D
No ASAM data for: "EV_AirbvAW20BPAVW26X" (SK26)
2 Faults Found:
9682162 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
9447189 - ROD - Unknown Error Code
          - 00 [137]
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 55199 km
                    Date: 2020.12.07
                    Time: 07:49:49
Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
   Part No SW: 6V0 920 740 A    HW: 6V0 920 740 A
   Component: KOMBI         205 1420
   Coding: 072501102180000801887E011000000000000000
   ASAM Dataset: EV_DsahBoardVDDMQBAB 009046
   ROD: N/A
   VCID: 336579FA9A775ADE5C-8066
No ASAM data for: "EV_DsahBoardVDDMQBAB" (SK26)
1 Fault Found:
16777022 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 215
                    Mileage: 55198 km
                    Date: 2020.12.12
                    Time: 02:39:46
Address 19: CAN Gateway (J533)       Labels:. 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 090
   Component: GW MQB A0     H08 0094
   Revision: --------    Serial number: 001388013566
   Coding: 030100082E0A640000000000000000000001050000000000000000000000
   ASAM Dataset: EV_GateaW0Lear 013020
   ROD: N/A
   VCID: 264390AE59A53F76CB-8072
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C0028090715
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 62191H54412826383466
No ASAM data for: "EV_GateaW0Lear" (SK26)
3 Faults Found:
1282 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 253
                    Mileage: 55198 km
                    Date: 2020.12.11
                    Time: 04:23:17
131654 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 253
                    Mileage: 55198 km
                    Date: 2020.12.11
                    Time: 00:21:46
8531970 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 61
                    Reset counter: 253
                    Mileage: 50848 km
                    Date: 2020.10.11
                    Time: 01:28:07
Address 2B: Steer. Col. Lock (J764)       Labels:. 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 15000174209001
   Coding: 5500000000000000
   ASAM Dataset: EV_ELVMraquMQB 004111
   ROD: N/A
   VCID: 34677AE69F795DE645-8060
No ASAM data for: "EV_ELVMraquMQB" (SK26)
2 Faults Found:
13635840 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 253
                    Mileage: 1048574 km
                    Date: 2000.00.00
                    Time: 00:00:00
13893632 - ROD - Unknown Error Code
          - 00 [008]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 29
                    Reset counter: 253
                    Mileage: 55198 km
                    Date: 2020.12.11
                    Time: 04:20:29
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CF7O0114
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6DD1AF82BCD3CC2E4A-8038
Address 5F: Information Electr. (J794)       Labels:. 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 840 A    HW: 5Q0 035 840 A
   Component: MU-S--ER      H24 0241
   Serial number: SKZAZ2R8724030
   Coding: 03620000BE0000001111000400000A002F0101D40120010004
   ASAM Dataset: EV_MUStd4CTAST 001022
   ROD: N/A
   VCID: 2B55619A4247021E14-807E
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H41 1028
   Serial number: SKZ8Z9RFF001CK
No ASAM data for: "EV_MUStd4CTAST" (SK26)
2 Faults Found:
1543 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 55198 km
                    Date: 2020.12.12
                    Time: 03:23:01
7207 - ROD - Unknown Error Code
          - 00 [009]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 215
                    Mileage: 55198 km
                    Date: 2020.12.12
                    Time: 03:23:04
End-------------------------(Elapsed Time: 03:05)--------------------------
