Caute. Od dnes rana sa mi stala nemila vec. Moja fabia (1,2 HTP 47kW Combi) mi pri jazde v zakrutach (inde sa mi to nestava) 3x zapipa (3x dlhsie pipnutie). Obcas je to pipnutie sprevadzane zasvietenou ikonou na pristrojovke, ako ked je zatiahnuta rucna brzda (cerveny vykricnik), rucna je vsak uvolnena. Inokedy zasa zapipa bez tejto ikonky. VAGom som dal skontrolovat casto pouzivane RJ, no az na par chyb v klimatizacii (predpokladam ze to s tym suvis nema), ziadna chyba ci uz v RJ motora, ABS (brzd) alebo Pristrojovej doske. Pre istotu prikladam vypis chyb:
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: XXX Mileage: 92370km/57396miles
Address 01: Engine Labels: Redir Fail!
Part No: 03E 906 033 A
Component: 1.2l/4V SIMOS3 00HS7001
Coding: 00071
Shop #: WSC 00000
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS.lbl
Part No: 6Q0 907 379 G
Component: ABS 5.7 FRONT V30
Coding: 00044
Shop #: WSC 13765
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0830
6 Faults Found
01271 - Positioning Motor for Temperature Flap (V68)
30-10 - Open or Short to Plus - Intermittent
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to Plus
28-10 - Short to Plus - Intermittent
41-10 - Blocked or No Voltage - Intermittent
29-10 - Short to Ground - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 25610
Shop #: WSC 13765
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 601 A
Component: 11 AIRBAG VW51 0008
Coding: 12593
Shop #: WSC 13765
Address 17: Instruments Labels: Redir Fail!
Part No: 6Y0 920 880 M
Component: KOMBI+WEGFAHRSP VDO V05
Coding: 00101
Shop #: WSC 13765
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 34 GATEWAY CAN 1S33
Coding: 00014
Shop #: WSC 13765
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 R
Component: LenkhilfeKYO V913
Coding: 10140
Shop #: WSC 13765
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 H
Component: 35 Komfortgerát 0002
Coding: 00019
Shop #: WSC 13765
End ---------------------------------------------------------------------
Dakujem za akekolvek rady, postrehy, navrhy, ktore by mi mohli pomoct v hladani chyby.
kontroloval jsi desky?.. teda jestli máš s čidlem.
Brzdove dosticky mam s cidlom, no nezda sa mi to ze to je tym, nakolko:
Ziadna chyba v RJ ABS/brzd, pipa to iba v zakrutach, a pri dostickach, ak sa nemylim, obycajne svieti symbol brzdoveho oblozenia (oranzove), kdezto tu mi svieti vykricnik cerveny (na striedacku svieti, nesvieti) a 3x pipanie
chladiacej kvapaliny mas dost???
A co třeba málo brzdové kapaliny.
Taky bych řekl že brzdovka...
dolej si brzdovku
Dakujem za pomoc, ako som si to mohol nevsimnut :) Jasne ze brzdova kvapalina... uz vyriesene a nepipa :)
Len mi neide do hlavy, preco sa to nezapisala ako chyba do RJ.. Kazdopadne vyriesene a mozete locknut.
