VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch ignition ON and leave the key to be resynchronised in the ignition.
2. Physically lock the vehicle using a second key in the driver's door lock. If you only have 1 key, lock the car from inside.
3. Using the remote control press the unlock button once, and the horn will sound once.
4. Wait for 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
· NOTE : When performing programming on additional remotes the procedure is the same, except you need to press the unlock button 2, 3 or 4 times for each different remote.
· For example : If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes - do not press 5 times or you will inadvertently erase all remotes (see below).
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
Remote Control Erasing (1997 ON)
Proces
1. Switch ignition ON and leave a key in the ignition.
3. Press the remote control unlock button 5 times in 1 second intervals. A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory erase.
5. Switch the ignition OFF, all remotes are now erased.
  • 4 měsíce později...
Preprog.klice -dalka (1997 NA)
Proces
1. Klic v zapalovani nechat v polohe Zapnuto
2. Manualne zavrit dvere druhym klicem ze ridic.strany,ak mate jenom jeden klic zamknout zevnitr
3. Jednim stlacenim na dalkovym ovladani-otevrit dvere se zapne alarm
4.Vyckat 6 vterin,pak zmacknout otevreni dveri,tim se aktivuje kodovaci proces a dalkove ovladani je preprogramovano (prispusobeno)
· POZNÁMKA : Ak preprog.vice dalek je proces ten samej, ale musi se znacknout otevreni 2,3 nebo 4 krat pro kazdy dalsi ovladac
· napríklad : Kdyz se preprogramujou 2 ovladace zmacknout odemceni dvakrát s 1 vterinovym intervalem mezi kazdym zmacknutim,opakovane pro 3 nebo 4 dalky nemackat 5 krat ,protoze se smazou vsechny dalky (cti dole)
5. Zapalovani do polohy vypnout
6. Vytahnout klic ze zapalovani,skontrolovat opreaci
7. Kodovani muze byt obnoveno az po 4 dalsich ovladacich
8. Zapalovani musi byt vypnuty medzi kazdym progr.dalsiho ovladani
Dalkove ovladani -mazani(1997 NA)
Proces
1. Zapalovani do polohy zapnuto a ponechat klic v zapalovani
3. Na dalkovem ovladani stalcit otevit dvere 5 krat za sebou ve vterinovem intervalu-spusti se alarm
4. Vyckat 6 vterin,zmacknout jednou otevrit dvere a pamet se vymaze
5. Vypnout zapalovani,vsechny dalky se vymazaly
