wlado93
Vše, co zveřejnil wlado93
  1. @valentintintin Hi, you can update only to 0367 (officially from 2xx to 2xx, from 3xx to 3xx, from 4xx to 4xx) without any modding. If you want update to bigger version 03xx -> 04xx you have to patch your unit, edit firmware and than you could update to 0478. But on bolero (without navigation) you have to disassembly your unit, and do some HW tricks (read memory via PC). And of course, after update all installed features working correctly. I had bought Smart Link before update, and after update it's working without reactivation needed. If you are interested PM me. BTW on units with navigation (2 SD slots) it's more simple. You don't need to do any HW tricks, it's just SD card method. Even activation of SWAP / FEC codes (Android Auto, Apple Car Play, Mirror Link...). And of course there is risk. If you don't have correct solution you can brick unit (but is possible to do recovery, but it's again HW tricks). And about changes, there is grid menu, some transition animations and support of Virtual Cockpit. But update to 0367 is no problem, only you have to be sure that your battery is in good condition and will not discharge during update, or keep engine running or connect to charger during update. Update process takes about 20 minutes with CLASS 10 SD card. On seat forum you probably read about Android Auto / Apple Carplay were disappeared from menu during update from 0245 >0330 > 0346. That items can be simply enabled with VCDS, but it's only during SEAT update 0245 >0330 > 0346. It's not happening during Skoda update. SK: Mozes updatovat len na 0367 (oficialne z 2xx na 2xx, z 3xx na 3xx, z 4xx na 4xx). Ak chces updatovat na vyssiu verziu 03xx -> 04xx musis patchnut jednotku a upravit firmware, a potom vies aktualizovat na 0478. Ale pri bolero (bez navigacie) musis rozobrat jednotku a spravit HW zasah (precitat pamat cez PC). Po aktualizacii samozrejme vsetky nainstalovane funckie funguju bez problemov. Ja som mal kupeny Smart Link pred aktualizaciou, a po aktualizacii funguje bez potreby reaktivacie. Ak mas zaujem napis mi spravu. Mimochodom na jednotkach s navigaciou (2 SD sloty) je to o mnou jednoduchsie. Nemusis robit ziaden HW zasah, je to ciste metoda s SD kartou. Taktiez aj aktivacia SWAP / FEC kodov (Android Auto, Apple Car Play, Mirror Link...). A samozrejme su tu rizika. Ak nemas spravne riesenie mozes bricknut jednotku (je mozne spravit obnovu, ale je to zas HW zasah). A ohladom zmien, je nove dlazdicove menu, nejake animacie prechodov a podpora Virtual Cockpitu. Ale update na 0367 nie je problem, akurat baterka musi byt v dobrej kondicii, aby sa nevybila pocas updatu, alebo nechaj bezat motor alebo pripoj na nabijacku pred updatom. Aktualizacia trva cca 20 minut s pouzitim CLASS 10 SD karty. Na seat fore si pravdepodobne cital ze Android Auto / Apple Carplay zmyzli z meno pocas updatu z 0245 >0330 > 0346. Tieto polozky sa daju jednoducho znova zapnut cez VCDS, ale to sa tyka len SEAT updatu 0245 >0330 > 0346. Nenastava to pri Skoda update.
  2. Islo o to ze na prvej stranke je link na temu kde sa riesia adaptery. Toto je tema kde sa riesi aplikacia a kodovanie...
  3. @LukášCBR Potvrdzujem funkcnost, zaklikol som to ako pises a alarm funguje :) samozrejme treba pockat asi 15 sekund po zamknuti kym sa aktivuje, ale myslim ze to tak mam aj pri seriovom alarme. Plus robil som update amundsenu a car scanner dokaze vymazat chybovu hlasku 1555 ktora sa objavi po aktualizacii. Normalne sa neda zmazat, cez VCDS je treba dokodovat XOR hodnotu. Car scanner to spravi jednym tuknutim :)
  4. Potvrdzujem funkcnost :) Aktualizovane z 0367 (Amundsen, Rapid MR17) Vdaka za firmware.
  5. @LukášCBR Skusal som to nastavit kamosovi na Seat Leon 2015 (elektrika ako O3) cez Caristu, ale nefungoval. Ked bude cas chcem to skusit cez VCDS pripadne CarScanner.
  6. 5.1 beta16 (Armeabi v7a + Arm64 v8a) v7a_Carista.ver.5.1.beta-16.build.510016.apks v8a_Carista.ver.5.1.beta-16.build.510016.apks
  7. Myslim ze to islo aj bez platenia ale musis mat beta verziu. Ak maju este miesto v beta programe urcite sa zapoj :) Beta updaty vychadzaju dost casto, ani to nestíham kontrolovat.
  8. Aplikacia ma velky potencial, preto som si ju aj kupil, tie 3-4 eura su smiesny peniaz za to co to dokaze. Sam som prekvapeny ze s obycajnym BT adapterom sa da spravit aj dlhe kodovanie. Kvoli VCDS som si kupoval HEX kabel za cca 30 eur. Skusal som cez to aktivovat senzor hladiny kvapaliny do odstrekovacov, zial nebola to len neaktivna funkcia ale tento senzor v aute naozaj nemam :D Co som si este vsimol tak nesedi uplne popis jednotlivych jednotiek. Carista je stale prehladnejsia, ale ak upravia dizajn a pridaju rychle nastavenia funkcii ako ma carista aplikacia by mohla konkurovat OBD ELEVEN. Co je tiez dovod preco som zaplatil, mozno cena pojde hore :)
  9. 5.1 beta15 (Armeabi v7a + Arm64 v8a) v7a_Carista.ver.5.1.beta-15.build.510015.apks v8a_Carista.ver.5.1.beta-15.build.510015.apks
  10. wlado93 odpověděl na Strabag's téma v Ostatní
    Tak dnes konecne prisiel a trvalo to "len" 100 dni :) Tak som spravil foto z montaze. Dosky tvarovo vyzeraju identicky. Dosku treba osadit podla tlacidiel, zvyraznene cervene obdlzniky. Povodna planzeta je o kusok sirsia, akurat o tie boky co som zvyraznil. Napriek tomu ale pekne pasuje do kluca. Nie je problem s vysunutim ani zasunutim. Planzetu je potrebne jemne dotuknut kladivom aby sadla do drazky ako na foto. Ide dnu o kusok tazsie ako ta cinska. Otvor na LEDku nebol dokonceny, tak som ho len prerazil najtensim torx bitom. Vzhladom na to ze ku klucu bolo VW logo kupil som skoda v auto kelly (5E0 837 891) cena 2.19 eur s registraciou. Po poskladani kluc posobi luxusnym dojmom, mam pocit ze je tensi ako povodny. Svetielko svieti, kluc funguje.
  11. Skus novsiu, posledna je 5.1 beta14, na predoslej strane mas aj V8 (64bit) aj V7 (32bit).
  12. Ahoj, pise ti to ze mas mat zapnute zapalovanie ale vypnuty motor. Takze len v prvej polohe, alebo tlacidlo stlacene bez spojky/brzdy.
  13. Lights: Daytime Running Lights (DRL) • Use left inner taillight as daytime running light • Use right inner taillight as daytime running light + mozes zmenit intenzitu svietenie v %, ja som nastavil 50 alebo 60 % • Left inner taillight as daytime running light brightness • Right inner taillight as daytime running light brightness Zhaznutie svetiel so zatiahnutou rucnou: • Turn off daytime running lights when parking brake is on
  14. Ahoj, mam 4 kusy Samsung Evo Plus 64GB na ktorych ide zmenit CID. Ked tak SS. Inzerat sa mi neda vytvorit, hadze to chybu EX0.
  15. Tak rozbehol som stary samsung a3 aby som vam dal aj 32bitovu aplikaciu. 21.8. mi konci beta program (dali mi ho len na mesiac, neviem ci to je standard) Takze do 21.8. budem pridavat uz aj 32bitovu verziu. 5.1 beta14 (Armeabi v7a) Carista.ver.5.1.beta-14.build.510014.apks
  16. 5.1 beta14 (Arm64 v8a) Carista.ver.5.1.beta-14.build.510014.apks
  17. @jaydoo tak mýlil som sa, nie je v infotainmente, ale na budikoch sa k tomu dostanes cez menu. A SS neviem, mozno skusit este VCDS. Ja som to robil cez to, este ked som nemal bluetooth adapter pre caristu.
  18. 5.1 beta13 (Arm64 v8a) Carista.ver.5.1.beta-13.build.510013.apks
  19. Na predoslej stranke bol popisovany podobny problem. Mas aktualizovany LP?
  20. Timer Lap su stopky na maxidote. Ak sa nezobrazuju je ich potrebne zaklliknut v infotainmente. Na start stop byva v casti Chassis & Engine • Disable auto start/stop system (method A) • Disable auto start/stop system (method C)
  21. 5.1 beta12 (Arm64 v8a) Carista.ver.5.1.beta-12.build.510012.apks
  22. 5.1 beta11 (Arm64 v8a) Carista.ver.5.1.beta-11.build.510011.apks
  23. Par stran dozadu mas postup na instalaciu apks suboru.
  24. Ahoj. Predpokladam ze si sa registroval aby si sa mohol opytat. Stahovanie suborov nahranych na forum sa da len pre prihlasenych, takze teraz by ti to uz malo ist. A predosly prispevok sa necituje.
  25. 5.1 beta10 (Arm64 v8a) Carista.ver.5.1.beta-10.build.510010.apks
