Vše, co zveřejnil Langusta 2018
Aplikacia Carista OBD2 + ELM327 adapter
Carista Pro 7.1 beta-10 New in Beta: - New Service tools for some VW/Audi/ Seat/Skoda models: * Fuel system priming * Throttle body adaptation Basic setting of transmission * Haldex pump learn calibration * HVAC flap calibration Carista Pro v7.1 beta-10.apk
Carista Pro 7.1 beta 5 WHAT'S NEW New in Beta: - New Service tools for some VW/Audi/Seat/Skoda models: * Fuel system priming * Throttle body adaptation * Basic setting of transmission * Haldex pump learn calibration * HVAC flap calibration Carista Pro v7.1 beta-5.apk
Carista Pro 7.0 beta-2 New in Beta: - New UI appearance Carista Pro 7.0 beta-2.apk
Udělal jsem to přes VCDS_a https://m.youtube.com/watch?v=0uy6XPrC3rU&feature=youtu.be
Tak, nainstalovat
Carista Pro 6.7 beta-3 New in Beta: New UI appearance Carista Pro 6.7 beta-3.apk
Carista Pro Final 6.6 Carista Pro Final 6.6.apk
Carista Pro 6.6 beta -19 New in Beta: - Electronic Parking Brake Service for BMW E, F, and G Chassis. - Live Data reading - Performance and stability improvements. improvements. Carista Pro 6.6 beta-19.apk
Carista Pro 6.6 beta-6 New in Beta: Electronic Parking Brake Service for BMW E, F, and G Chassis. Live Data reading improvements. Performance and stability improvements. Carista Pro 6.6 beta-6.apk
Carista 6.5.2 Carista 6.5 beta 12 Disable auto start/stop system (method A) (may not work on 2019+ models) *YES (12.1V LIMIT)* / YES (12.0V LIMIT) / NO (9.0V LIMIT) / NO (8.2V LIMIT) / NO (8.0V LIMIT) / NO (7.8V LIMIT) / NO (7.6V LIMIT) / NO (7.4V LIMIT) / NO (7.0V LIMIT)
Carista Pro 6.5.2 Carista Pro 6.5.2.apk
Možnosti kódování u OIII
Venkovní teplota - doba uložení do paměti po vypnutí motoru. Kódování; CE 09 (Central Electrics) Úpravy Zabezpečení přístupu -> 47115 Sada indikátorů 17 Změňte hodnotu na požadovanou - standardně 180 min (nastavil jsem na 60 min) S tímto modem se venkovní teplota aktualizuje i při volnoběhu.
Carista Pro 6.5.1 Carista Pro 6.5.1.apk
Air Care Climatronic Přesně to kódování
Air Care Climatronic Systémy Climatronic ve vozech ŠKODA zvyšují komfort a bezpečnost cestujících. Ve spojení se systémem kvality vzduchu (AQS) se Climatronic automaticky přepne do režimu recirkulace vzduchu, jakmile senzory detekují znečištění venkovního vzduchu. Vysoce účinné filtry systému Air Care navíc neustále čistí vzduch uvnitř vozidla. Díky tomu jsou částice, pyl a nepříjemné pachy účinně absorbovány. Aktivace funkce čištění vzduchu Air Care Climatronic. Climatronic, moje auto 02.2017, na panelu klimatizace není nápis "Air Care", tak jsem zkusil tuto funkci zapnout. Přejděte na 08 Klimatizace kódování: Dlouhé kódování Byte 15 Bit 5-6 kontrola -> 20 Nainstalovaná filtrace vzduchu v kabině. V mém kódování na poslední fotce chybí "Bit" Pozornost; pokud není k výběru žádný bit, musí být kódování změněno z "ruky" Funkce Air Care se používá pro režim řízené recirkulace uvnitř vozidla. Intenzita recirkulace závisí na vlhkosti vzduchu ve vozidle a venkovní teplotě (nebezpečí zamlžení skel). > Pro zapnutí/vypnutí stiskněte tlačítko MENU na ovládacím panelu Climatronic a poté stiskněte funkční tlačítko AR CARE → Active na obrazovce Infotainment » Aby Air Care správně fungovala, musí být zavřené všechny dveře a okna, včetně panoramatické posuvné/výklopné střechy. Při otevření dveří nebo okna (případně panoramatické posuvné/výklopné střechy) se na obrazovce informačního systému zobrazí zpráva.
Kódování funkcí na Superba III (VCDS)
Kompenzace krouticího momentu (TSC) Aktivace TSC 1. Zadejte „Steering Assist“ na adrese 44 přístupový kód (19249) 2. Pak v dlouhém kódování 3. Změňte hodnotu: z neaktivní kompenzace řízení krouticího momentu (TSC) na 1_Torque Steer Compensation (TSC) s naučenými hodnotami aktivní nebo 2_Torque Steer Compensation (TSC) bez aktivních naučených hodnot (Pozice 2 pak funkce pracuje tvrději) Kompenzace točivého momentu (TSC) – Tato funkce mění nastavení kompenzace točivého momentu a zlepšuje stabilitu řízení při akceleraci. Podstatou systému je kompenzace smyku vozu v okamžiku zrychlení (při prudké akceleraci vozů s předním náhonem mírně driftuje doprava). Ukázkové video VW Tiguan bez funkce TSC 0_Torque Steer Compensation (TSC) neaktivní 1_Torque Steer Compensation (TSC) s naučenými hodnotami aktivní 2_Torque Steer Compensation (TSC) bez aktivních naučených hodnot 0_ Kompenzace točivého momentu (TSC) není aktivní. 1_ Kompenzace točivého momentu (TSC) aktivní s naučenými hodnotami. 2_Kompenzace točivého momentu (TSC) aktivní bez naučených hodnot.
Carista Pro 6.5 beta-12 Carista Pro 6.5 beta-12.apk
Ak inštalujete na fungujúci súbor apk, nie je potrebné nič upravovať. Iba pri prvej inštalácii je potrebné upraviť čistý apk.
Akustické potvrdenie odomykania-zamykania až po druhom stlačení tlačidla na diaľkovom. Zapol som a Octavia III FL funguje krásne
Carista Pro 6.4.1 Carista Pro 6.4.1.apk
Turn off front fog lights when high beams are on YES / *NO*
Pokud instalujete přes předchozí verzi, bude to fungovat. Pokud jej instalujete poprvé, používáte LP
Dobrý den, můžete sdílet kódování, které jsem chtěl zkontrolovat ....😉
