Kejml22
Uživatel-
44 -
Typ obsahu
Profil
Fórum
Galerie
Obchod
Stahování
Articles
Vše zveřejněné uživatelem Kejml22
Sháním někoho kdo by mi nakódoval columbuse nejlépe Karlovarský kraj.
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: 000G GATEWAY CAN 2S36 Coding: 00014 Shop #: WSC 13765 VCID: F0E54E19B0B8B29 3 Faults Found: 01300 - Control Module for Navigation with CD-Rom (J401) 49-10 - No Communications - Intermittent 01304 - Radio 49-10 - No Communications - Intermittent 01341 - Control Module in Instrument Panel On Comfort CAN (J285) 49-00 - No Communications
ještě výpis z jednotek Address 37: Navigation (J0506) Labels: 1T0-035-680.clb Part No SW: 3T0 035 680 B HW: 3T0 035 680 E Component: RNS-MID H70 4024 Revision: AB001001 Serial number: -------------- Coding: 06000400040100830000 Shop #: WSC 25941 260 10892 ASAM Dataset: ------------------------- ------ VCID: 2F670D657D066D1 7 Faults Found: 00857 - CD Changer Unit (R41) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 5 Fault Frequency: 74 Reset counter: 229 Mileage: 115864 km Time Indication: 0 00873 - Bass Speaker Rear Right (R17) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 39 Reset counter: 229 Mileage: 115864 km Time Indication: 0 00877 - Treble Speaker Rear Right (R16) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 14 Mileage: 115864 km Time Indication: 0 00872 - Bass Speaker Rear Left (R15) 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 39 Reset counter: 229 Mileage: 115864 km Time Indication: 0 00876 - Treble Speaker Rear Left (R14) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 6 Reset counter: 14 Mileage: 115864 km Time Indication: 0 00856 - Radio Antenna 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 39 Reset counter: 229 Mileage: 115864 km Time Indication: 0 03138 - Input AUX IN 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 229 Mileage: 0 km mám VCDS11.11
Zdravím koupil jsem Columbuse a mám jeden problém. Při vypnutí zapalování a vytažení klíčku se Columbus nevypne úplně, slyším jak si chroustá HDD. Ani když se zamknu v autě tak je to tejné. Když podržím restart tak se vypne což je asi v pořádku. Verze columbuse 3T0 035 680 B HW: H70 SW: 4024 Map 7894 000G Gateway can 2s36 00014 WSC 13765 Nemohlo by to také být zapojením svorka + a SAFE jsou vedeny jedním drátém. Jinak se omluvám že píši sem rádio dávám do Fabie II předface ale v sekci ve fabii nikdo neodpovídá. Příadně děkuji za rady kdyby informace nybli kompletní doplním
Mám problém připojil jsem Columbuse a i po vypnutém zapalování a zamknutí voze. Je slyšet jak dál pracuje, mám strach aby se nevybila baterka. Je možné že ho mám zapojený špatně nebo je to otázka FW rádia?
Zdravim potreboval bych pomoct se zapojenim prevodniku. Nemate nekdo schema? Koupil jsem columbuse a nevim kam ho mam zapojit.Fabia II r.v. 2008 předface a měl jsem přípravu pro neorig autorádio
Zdravím potřeboval bych poradit. Koupil jsem columbuse a chtěl bych ho nainstalovat. Mám předface FII nemam Maxidot. Zjistil jsem že mám pouze ISO konektory. Co budu potřebovat k instalaci? Potřebuji vůbec převodník sice plánuji Maxidot ale není nikde k sehnání. Díky za radu
Zdravím mám problém. Když nechám rozsvícená světla po zhasnutí motoru a otevřu dveře nefunguje mi hlasové upozornění. A také dokud nevypnu a nevytáhnu klíček ze zapalování. A někdo otevře dveře zůstane mi svítit signalizace otevření dveří i po jejich zavření a i když vytáhnu klí a zamnknu auto. Nevíte někdo co s tím? Zkoušel jsem přes VAG dát základní nastavení přístrojové desky ale nepomohlo to.
A nemáte někdo Maxidota na prodej do 11/2008 1.9 tdi Fabia II... nemůžu ho nikde sehnat.
Mám dotaz vlastním Fabii II 1.9 tdi 11/2008 lze do ní nainstalovat maxidot z 1.6tdi facelift? Díky
Ahoj chci se zeptat který maxík bude pasovat do 1.9tdi fabie II r.v. 2008 http://viewitem.eim.ebay.cz/Skoda-Fabia-Mk2-5J-2007--14L-Diesel-Speedo-Head-/400329840358/item nebo http://viewitem.eim.ebay.cz/Skoda-Fabia-Mk2-5J-2007--16L-Diesel-SE-PLUS-TDI-Speedo-Head-/271219644494/item díky
Jsem z karlovarského kraje
Zdravím jak jsem zmiňoval pořídil jsem Maxidot z 1.4tdi. Sehnal jsem člověka který mi ho měl vyměnit. Ale nastali problém. Maxík z 1.4 tdi prý neumí přijmout můj kód z imobilizéru že prý jednotka má zafixovaný jiný a nejde přehrát. I zkoušel dát nový imobilizér do mých klíčů. Podle něj mám zajet do autorizovaného servisu škoda kde mi smažou celou jednotku. Ale člověk který mi Maxidot prodal, napsal že při připojení online databází škoda se jednotka zablokuje. Kde je pravda poraďte prosím? Děkuji
Ahoj koupil jsem MAxidota na Fabii II předface (5J0920840C)púokud jsem pochopil dobře PIN najdu na orig. klíčích. Na jaké verzi VAGu se nejlépe naprogramuje Maxidot. Potřebuji ještě něco pro instalaci? Děkuji
Zdravím koupil jsem budíky z 1.4tdi Fabie II lze to použít do 1.9tdi?
Lze u navigace DX přehrát navigační software?
Chtěl bych se zeptat jestli jsou u FII ambiente vzádu repro nebo to je pouze za příplatek? Díky
vyřešeno po sundání sedačky a rozdělaní toho mechanismu
Polohovat s páčkou jde ale nic se neděje ani jedním směrem.
Ano polohopvání mám ale nefunguje.
špatně jsem se vyjádřil u sedačky řidiče nejde polohovat sedačku
Koupil jsem FII a nejde u ní polohovat sedačku nahoru a dolů, nemáte někdo zkušenost co by s tím mohlo být? díky
