COLUMBUS (TRINAX) / RNS 510 - Stránka 52 - Autohifi, Navigace - ŠKODA Forum - SKODAHOME.cz Přejít na obsah
Napokon sa mi podarilo ten FW 1020 cez torrent stiahnuť (za temer 2 dni). BTW lala30 - nerozumel som ti ani slovo. Keď píšeš, tak pred tým nechlastaj :) Alebo už existuje aj novší FW pre 1Z0 než 1020?
Má niekto zapojený originálny TV tuner? Po jeho pripojení je potrebné ešte RNS aj inak nakódovať? Na nete som totiž nikde nenašiel kódovanie, kde by bol spomenutý aj TV tuner. Alebo to hneď začalo fungovať samo?
Odkaz ke komentáři
Sdílet na ostatní stránky
> ; VAG-COM Label File
> ; Seat Altea/Toledo (5P) / Seat Leon (1P) / Skoda Octavia (1Z) / Skoda Superb (3T)
> ; VW Caddy (2K) / VW Golf/Jetta (1K/5M) / VW Passat (3C) / VW Touareg (7L) / VW Touran (1T)
> ; Component: J506 - Radio-/Navigation System (#37/56) - RNS510
> ; P/N: 1T0-035-680-??? / 1Z0-035-680-??? / 3C0-035-68?-??? / 5P0-035-680-???
> ; 7L6-035-680-???
> ; includes measuring blocks, adaptation, long coding and selective output tests
> ; created on 10/Oct/2007 by Sebastian Stange (Sebastian@Ross-Tech.com)
> ; last modification: 29/Mar/2008
> ; requires VAG-COM 707.0 / LCode 710.2 or newer
> ; measuring blocks
> 001,0,General
> 001,1,Supply Voltage,(Terminal 30),Specification: 9.0...15.0 V
> 001,2,Dimming,(Terminal 58s),Range: 0.0...100.0 %
> 001,3,Dimming,(Terminal 58d),Range: 0.0...100.0 %
> 001,4,Status,S-Contact (CAN),Range: ON/OFF
> 002,0,Telephone
> 002,1,Telephone
> 002,2,Mute Status,(Analog),Range: ON/OFF
> 002,4,Mute Status,(CAN),Range: ON/OFF/Not Recognized
> 003,0,Speaker/Line-Out (Front Left)
> 003,1,Location/Type,,Range: Line-Out F/Lf / Spkr. Frt/Lft
> 003,2,Status,,Range: OK/Short Circuit/Open Circuit
> 004,0,Speaker/Line-Out (Front Right)
> 004,1,Location/Type,,Range: Line-Out F/Rt / Spkr. Frt/Rt
> 004,2,Status,,Range: OK/Short Circuit/Open Circuit
> 005,0,Speaker/Line-Out (Rear Left)
> 005,1,Location/Type,,Range: LLine-Out R/Lf / Spkr. R/Lft
> 005,2,Status,,Range: OK/Short Circuit/Open Circuit
> 006,0,Speaker/Line-Out (Rear Right)
> 006,1,Location/Type,,Range: Line-Out R/Rt / Spkr. R/Rt
> 006,2,Status,,Range: OK/Short Circuit/Open Circuit
> 007,0,Remote Feed Antenna I
> 007,1,Antenna Type,,Range: Active
> 007,2,Component
> 007,3,Status,,Range: OK/Short Circuit/Open Circuit
> 008,0,Signal Strength
> 008,1,Signal Strength
> 008,2,Signal Strength,Tuner I
> 008,3,Signal Strength
> 008,4,Signal Strength,Tuner II
> 010,0,Remote Feed Antenna II
> 010,1,Antenna Type,,Range: Active
> 010,2,Component
> 010,3,Status,,Range: OK/Short Circuit/Open Circuit
> 011,0,Communication Status CD-Changer (R41)
> 011,1,Component
> 011,2,Status,,Range: OK/Not OK
> 011,4,Communication,Status
> 013,0,Communication Sound System (DSP)
> 013,1,Component
> 013,2,Status,,Range: OK/Short Circuit/Open Circuit
> 020,0,Card Reader
> 020,2,Card Reader,Status,xxxxxxx? = Card Reader ready\nxxxxxx?x = SD-Card recognized and valid\nxxxxx?xx = SD-Card reading\nxxxx?xxx = SD-Card writing\nxxx?xxxx = No Card\nxx?xxxxx = MMC Card\nx?xxxxxx = SD-Card write protected\?xxxxxxx = Error
> 020,3,Memory Card,Capacity
> 020,4,Memory Card,Free Capacity
> 025,0,Internal Control Module Malfunctions
> 025,1,Control Module,Status,Specification: 0\n\n0 = No Error recognized\n1 = Button(s) jammed\n2 = Checksum Error ROM/EPROM/Flash-ROM\n3 = Checksum Error EEPROM\n5 = CD/DVD-Drive Error
> 030,0,SDARS (Sirius)
> 030,1,Service ID,Sirius Audio
> 031,0,SDARS (Sirius)
> 031,1,Service ID,Sirius Traffic
> 032,0,SDARS (Sirius)
> 032,1,Sirius Service,Status,1 = No Signal\n2 = Signal Quality insufficient\n3 = Signal Quality good\n4 = Signal Quality very good
> 032,2,Sirius Service,Mute Status,Range: Yes/No
> 032,3,Sirius Service,Current Channel
> 032,4,Sirius Service,Adjustment,xx1 = Country\nx1x = SAT1\n1xx = SAT2
> 033,0,SDARS (Sirius Audio)
> 033,1,Sirius Audio,subscribed,Range: Yes/No
> 033,2,Sirius Audio,Mute Status,Range: Yes/No
> 033,3,Sirius Audio,activated,Range: Yes/No
> 033,4,Sirius Audio,Activation Time
> 034,0,SDARS (Sirius Traffic)
> 034,1,Sirius Traffic,subscribed,Range: Yes/No
> 034,2,Sirius Traffic,Mute Status,Range: Yes/No
> 034,3,Sirius Traffic,activated,Range: Yes/No
> 034,4,Sirius Traffic,Activation Time
> 035,0,SDARS (Regional Code)
> 035,1,Regional Code,Flash
> 035,2,Regional Code,PSV
> 035,3,Regional Code,eGCI
> 035,4,Regional Code
> 036,1,SDARS (Sirius)
> 040,0,DAB
> 041,0,DAB
> 042,0,DAB
> 051,0,Allgemein
> 051,1,Status,Terminal 15,Range: Term. 15 ON/Term. 15 OFF
> 051,2,Status,Reverse Gear
> 051,3,Speed Signal,(CAN)
> 051,4,Speed Signal,(Status)
> 052,0,GPS-Reception
> 052,1,Component
> 052,2,Used,Satellites
> 052,3,Visible,Satellites
> 053,0,Geographic Position (Longitude)
> 053,1,Longitude
> 054,0,Geographic Position (Latitude)
> 054,1,Latitude
> 055,0,Device Temperture Monitoring
> 055,1,Temperature
> 055,2,Temperature,Status
> 055,3,Current Device,Temperature
> 056,0,DVD-Drive (Read Errors)
> 056,1,DVD-Drive,Read Errors
> 056,2,Status,Read Errors
> 056,3,Number of,Read Errors
> 057,0,DVD-Drive (Access Time)
> 057,1,DVD-Drive,Access Time
> 057,2,DVD-Drive,Access Time
> 058,0,DVD-Drive (Read Errors/Access Time)
> 058,1,DVD-Drive,Read/Access
> 058,2,Status,Read Errors
> 058,3,Number of,Read Errors
> 058,4,Access Time
> 059,0,Wakeup Reason
> 059,1,Wakeup Reason
> 059,2,Wakeup Reason
> 059,3,Wakeup Reason,CAN-Messages
> 060,0,DVD-Drive
> 060,1,Status,DVD-Drive
> 060,2,Status,DVD-Drive,0 = Ready, No DVD/CD\n1 = Ready, Load/Eject in progress\n2 = Ready, No DVD/CD inserted\n3 = Medium recognized but Rear Error\n4 = Medium recognized and OK\n5 = Load/Eject Error\n6 = Error (Initialisation failed)\n7 = Over-Temperature, Drive deactivated\n8 = Positioning Error\n9 = Voltage Error, Drive deactivated\n15 = Unknown Error
> 060,3,Regional Code
> 060,4,Regional Code,rem. Changes
> 061,1,Satellite-ID,(best Signal)
> 061,2,Signal Level,(best Signal)
> 061,3,Satellite-ID,(sec. best Signal)
> 061,4,Signal Level,(sec. best Signal)
> 062,1,Satellite-ID,(best Signal)
> 062,2,Signal Level,(best Signal)
> 062,3,Satellite-ID,(sec. best Signal)
> 062,4,Signal Level,(sec. best Signal)
> 063,0,GPS-Antenna
> 063,1,Component
> 063,2,Status,,Range: OK/Short Circuit/Open Circuit
> 065,1,Hardkeys
> 065,2,Hardkeys
> 066,0,Buttons
> 066,1,Button Status,,1x = Rotary Knob pressed\nx1 = Volume Knob pressed
> 066,2,Volume Knob
> 066,3,Rotary Knob
> 070,0,CAN-Data Bus Communication
> 070,1,TV-Tuner,,Range: TV-Tuner 0/TV-Tuner 1
> 090,0,Speech Dialog System (SDS)
> 091,0,Speech Dialog System (SDS)
> 093,0,Multifunction Steering Wheel Buttons
> 093,1,Buttons
> 093,2,Button,Status
> 094,0,Communication Electronic-Toll-Collect (ETC)
> 095,0,DVD-Drive Status
> ;095,1,,,
> ;DVD Status, ,
> ;095,2,,,
> ;1.0,(no units),
> ;095,3,,,
> ;5.0,(no units),
> 107,0,Remote Feed Antenna I
> 107,1,Connection
> 107,2,Radio
> 107,3,Antenna
> 107,4,Status,,Specification: OK
> 110,0,Remote Feed Antenna II
> 110,1,Connection
> 110,2,Radio
> 110,3,Antenna
> 110,4,Status,,Specification: OK
> 127,0,Software Version (Siemens/VDO)
> 127,1,Software Version,(Siemens/VDO)
> ; adaptation
> A010,0,Remote Control
> A010,5,Remote Control
> A010,6,0 = Playback disabled
> A010,7,1 = Playback enabled
> A010,8,
> A010,9,Note: After closing the Diagnostic Session/Communication
> A010,10,the Standard Value 0 is automatically being restored.
> A011,0,Remote Control: Source
> A011,5,Remote Control: Source
> A011,6,0 = FM
> A011,7,1 = AM
> A011,8,
> A011,9,Note: After closing the Diagnostic Session/Communication
> A011,10,the Standard Value 0 is automatically being restored.
> A012,0,Remote Control: Frequency FM
> A012,5,Remote Control: Frequency FM
> A012,6,The Frequency Adjustment is being carried out
> A012,7,incrementally starting with 0 = 88.3 MHz.
> A012,8,
> A012,9,Note: After closing the Diagnostic Session/Communication
> A012,10,the Standard Value 0 is automatically being restored.
> A013,0,Remote Control: Frequency AM
> A013,1,Remote Control: Frequency AM
> A013,6,The Frequency Adjustment is being carried out
> A013,7,incrementally starting with 0 = 540 kHz.
> A013,8,
> A013,9,Note: After closing the Diagnostic Session/Communication
> A013,10,the Standard Value 0 is automatically being restored.
> A014,0,Remote Control: Volume
> A014,5,Remote Control: Volume
> A014,6,Range: 0...100
> A014,7,Standard: 40
> A014,8,
> A014,9,Note: After closing the Diagnostic Session/Communication
> A014,10,the Standard Value 0 is automatically being restored.
> A015,0,Remote Control: Balance
> A015,5,Remote Control: Balance
> A015,6,Note: After closing the Diagnostic Session/Communication
> A015,7,the Standard Value 0 is automatically being restored.
> A016,0,Remote Control: Fader
> A016,1,Remote Control: Fader
> A016,6,Note: After closing the Diagnostic Session/Communication
> A016,7,the Standard Value 0 is automatically being restored.
> A17,0,
> ;0
> A18,0,
> ;0
> A19,0,
> ;255
> A20,0,
> ;0
> A43,0,
> ;0
> A44,0,
> ;0
> A050,0,Development Test Mode
> A050,5,Development Test Mode
> A050,6,To Enable the Development Test Mode save "1" as new value.
> A121,0,
> ;0
> A125,0,
> ;0
> A130,0,
> ;0
> A131,0,
> ;3
> A132,0,
> ;6
> ; long coding
> ; (Radio Configuration I)
> LC,00,1,CD-Changer/iPod/USB Connection Monitoring active
> LC,00,2,AUX-Input Connection Monitoring active
> LC,00,3,Parking Aid/Park SteerAssist Monitoring inactive
> ; (Sound System Correction)
> LC,01,0~7,00,Soundsystem not installed
> LC,01,0~7,01,Volkswagen Soundsystem
> LC,01,0~7,02,Skoda Soundsystem (CAN DSP)
> LC,01,0~7,05,Dynaudio Soundsystem
> LC,01,0~7,06,Volkswagen Soundsystem (BAP DSP)
> LC,01,0~7,07,Dynaudio Soundsystem (BAP DSP)
> ; (Speaker Channels)
> LC,02,0~7,00,Sound System (active Speakers)
> LC,02,0~7,02,2 Speaker Channels (Front only)
> LC,02,0~7,04,4 Speaker Channels (Front and Rear)
> ; (Radio Configuration II)
> LC,03,1,Microphone Diagnostics active
> LC,03,6,Back-Up Camera Low (without Control Module) installed
> ; (Treble Speaker Monitoring)
> LC,04,0~7,01,Not coded
> LC,04,0~7,01,Speaker Monitoring: inactive (Sound System)
> LC,04,0~7,02,Speaker Monitoring: Front active / Rear inactive
> LC,04,0~7,03,Speaker Monitoring: Front inactive / Rear active
> LC,04,0~7,04,Speaker Monitoring: Front and Rear active
> ; (Vehicle Specific Equalization)
> LC,05,0~7,00,Equalization: Linear
> LC,05,0~7,01,Equalization: Seat Altea (5P) / Skoda Octavia (1Z)
> LC,05,0~7,02,Equalization: Seat Leon (1P)
> LC,05,0~7,03,Equalization: Seat Toledo (5P)
> LC,05,0~7,04,Equalization: Seat Altea XL (5P) / Skoda Superb (3T)
> ; (Radio Configuration III)
> ; Byte 06 only for Audi
> ; (Navigation System Configuration I)
> LC,07,0,Multifunction Steering Wheel installed
> LC,07,1,Voice Control inactive
> LC,07,2,Speed Threshold for Destination Input active
> LC,07,3,Speed Threshold for Speech Destination Input active
> LC,07,4~5,00,Display Variant: Highline
> LC,07,4~5,10,Display Variant: Sportsline
> LC,07,4~5,20,Display Variant: Premium
> LC,07,7,Communication Instrument Cluster via Operation and Display Protocol (BAP)
> ; Byte 07 Bit 7: 0 = Display Data Protocol (DDP) / 1 = Operation and Display Protocol (BAP)
> ; (Navigation System Configuration II)
> LC,08,4,Logo Company FAW (ONLY Japan/China)
> ; selective output test
> T3042,Speaker Front Left
> T3043,Speaker Front Right
> T3044,Speaker Rear Left
> T3045,Speaker Rear Right
> T419,Midrange Speaker Front Left (R103)
> T420,Midrange Speaker Front Right (R104)
> T421,Midrange Speaker Rear Left (R105)
> T422,Midrange Speaker Rear Right (R106)
> T870,Bass Speaker Front Left (R21)
> T871,Bass Speaker Front Right (R23)
> T872,Bass Speaker Rear Left (R15)
> T873,Bass Speaker Rear Right (R17)
> T874,Treble Speaker Front Left (R20)
> T875,Treble Speaker Front Right (R22)
> T876,Treble Speaker Rear Left (R14)
> T877,Treble Speaker Rear Right (R16)
> T854,Display Test
> T2875,CD/DVD-Drive: Short Test
> T2876,CD/DVD-Drive: Random Test
Když tak to někdo alespoň srozumitelně přeložte do češtiny
Odkaz ke komentáři
tady je bohužel problém v tom, že uvedené dlouhé kódování je 8bytové, kdežto nové 510 mají 9bytové (zkoušeno na Superbové "T" )
Byte 00 Radio Configuration I
Bit 1 External CD Changer Connection active
Bit 3 Parking Aid Monitoring inactive (Standard)
Byte 01 Sound System Correction
00 Sound System not installed
01 Volkswagen Sound System
02 Skoda Sound System
05 Dynaudio Sound System
Byte 02 Speaker Channels
00 Sound System (active Speakers)
02 2 Speaker Channels (Front only)
04 4 Speaker Channels (Front and Rear)
Byte 03 Radio Configuration II
Bit 1 Microphone Diagnostics active (Japan/China only)
Byte 04 Treble Speaker Monitoring
01 Monitoring inactive
02 Front Monitoring active / Rear Monitoring inactive
04 Front and Rear Monitoring active
Byte 05 Vehicle Specific Frequency Response
00 Volkswagen/Skoda (all)
01 Seat Altea (5P)
02 Seat Leon (1P)
03 Seat Toledo (5P)
04 Seat Altea XL (5P)
Byte 06 Radio Configuration III
00 Standard/Not Relevant
Byte 07 Navigation System Configuration I
Bit 0 Multifunction Steering Wheel installed
Bit 1 Voice Control inactive (NOT Japan/China)
Bit 2 Speed Threshold for Destination Input active
Bit 3 Speed Threshold for Speech Destination Input active
Bit 4+5 Display Variant
Byte 08 Navigation System Configuration II
Editováno: , autor: rolbař
Odkaz ke komentáři
vlastně ne, bylo to zkoušeno na Zkové, on měl prohozené jen přední panely, proto se mi to zafixovalo jako Tčková
bylo to u Harleye
Kdyby to byla Tčková, tak nevyjíždí z maxidótu
doufám, že se nepletu, střídaly se dvě navigace s prohozenýma panelama :) Harley to snad objasní
Odkaz ke komentáři
  rolbař napsal:
bylo to u Harleye
Je to 1Z navigace s čelním panelem z 3T , jak to vypadá s těma čidlama na parkování ?? Pomůže prohodit jednotky park senzorů za tu ze supa ????? Nebo to prostě nepůjde ?? A ví někdo něco nového , proč to klukům nevyjíždí z tohomenu na Maxi - dotu ??
Odkaz ke komentáři
Pánové, nevíte kde zjistit, jaká je nejnovější verze Map do Columbuse. V servisu vědí starou belu. Nemá Navteq nějaké stránky s e-shopem, jako má TeleAtlas?
Sháním nejnovější mapu Východní Evropy. Zatím mám verzi 6161 a za měsíc jedu do Chorvatska, tak bych chtěl nějakou aktuálnější.
Odkaz ke komentáři
  • o 2 týdny později...
Ahoj,
má někdo zkušenosti s propojením a komunikací telefonu (jakéhokoliv typu) se systémem COLUMBUS v O2? Nechci mít v autě další mikrofonky a drátky pro HF nebo na palubce přidělaný PARROT, preferuji využít COLUMBUS ke komunikaci s phonem. Má COLUMBUS Bluetooth? Jak komunikuje s phonem? Je nutná příprava pro mobilní telefon?
Díky za názory a zkušenosti.
KOTAS
Odkaz ke komentáři
