dadyka
  1. Ahojte.nevedel by mi niekto poradit objednavacie cislo pinu do RJ motora do fabie 2 facelift htp.diky
  2. dadyka odpověděl na dadacek's téma v Elektrika
    ahoj.mam problem s octaviou 2 1,6 benzin r.v.:2005 ked nastartujem tak svieti kontrolka ABS ASR a Serva a este aj blika kontrolka poruchy brzd aj to pipa.ked to necham bezat cca 2minutky a znova nastartujem tak uz nic nesvieti.robi to aj niekedy pocas cesty ze sa rozsvietia kontrolky.auto ide normalne.baterka je nova a alternator teraz bol na repase.prosim poradte.diky VCDS Version: Release 908.0 Data version: 20090911 Saturday,01,November,2014,14:25:09:13314 Chassis Type: XXX Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 VIN: TMBCA21ZX62152996 Mileage: 158900km/98735miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 1010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Not registered 0011 ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 06A 906 033 FB Component: SIMOS71 1.6l 2V 7004 Revision: --H01--- Serial number: SKZ7Z0E3118986 Coding: 0000071 Shop #: WSC 73430 790 00000 2 Faults Found: 28793 - No Communication with ABS Brake Control Module U0121 - 009 - Open or Short to Ground - Intermittent Freeze Frame: RPM: 0 /min Mass Air / Rev.: 0.0 mg/str Bin. Bits: 00000001 Hex Value: 0x0000 RPM: 0 /min Mass Air / Rev.: 0.0 mg/str Bin. Bits: 00000001 Hex Value: 0x0000 18327 - Load Signal from Alternator Term. DF: Short to Ground P1919 - 007 - Short to Ground Freeze Frame: Voltage: 12.34 V RPM: 0 /min Duty Cycle: 99.6 % Hex Value: 0x0002 Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 73430 790 00000 1 Fault Found: 00003 - Control Module 014 - Defective - Intermittent ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No: 1Z0 820 047 D Component: Climatic PQ35 010 0301 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000003512665 Coding: 11040E011004140000110D000000000000197F0741 Shop #: WSC 29653 654 58047 Part No: 1Z1 955 119 A Component: Wischer SK351 012 0401 Coding: 00065525 Shop #: WSC 29653 2 Faults Found: 02394 - Parking Light Left Front (M1) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 96 Mileage: 158438 km Time Indication: 0 Freeze Frame: ON Voltage: 14.25 V ON ON OFF OFF ON 01259 - Fuel Pump Relay (J17) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 5 Fault Frequency: 254 Reset counter: 129 Mileage: 151746 km Time Indication: 0 Freeze Frame: OFF Voltage: 11.95 V OFF ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 N HW: 1K0 909 605 N Component: Q2 AIRBAG VW8 015 2100 Revision: 03015000 Serial number: 0038ED0JXH9U Coding: 0020786 Shop #: WSC 73430 790 00000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF Component: Lenksäulenmodul 034 0070 Coding: 0000012 Shop #: WSC 73430 790 00000 1 Fault Found: 00888 - Wiper Switch for Intermittent Operation (E22) 014 - Defective - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1Z0 920 810 B Component: KOMBIINSTRUMENT VD1 3562 Coding: 0003101 Shop #: WSC 80093 222 69422 1 Fault Found: 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 F HW: 1K0 907 951 Component: Gateway H10 0120 Revision: H10 Serial number: 28001057248D99 Coding: 3D0F0300071302 Shop #: WSC 73430 790 00000 2 Faults Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 1 Fault Frequency: 254 Reset counter: 89 Mileage: 151746 km Time Indication: 0 Date: 2000.00.00 Time: 17:24:41 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 21 Reset counter: 129 Mileage: 158588 km Time Indication: 0 Date: 2000.00.00 Time: 05:23:38 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl Part No: 1Z0 920 810 B Component: IMMO 3562 Shop #: WSC 00000 000 00000 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1T0 959 701 B Component: Tuer-SG 024 2345 Coding: 0000244 Shop #: WSC 73430 790 00000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 J Component: EPS_ZFLS Kl.0 D04 1606 Shop #: WSC 00000 000 00000 1 Fault Found: 00625 - Vehicle Speed Signal 004 - No Signal/Communication - Intermittent Freeze Frame: Mileage: 8560 km Temperature: 11.0°C Voltage: 11.60 V Voltage: 11.40 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb Part No: 1K0 959 433 AH Component: KSG 0401 Coding: 00D002003F098505094B010004CC Shop #: WSC 73430 790 00000 Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1T0 959 702 B Component: Tuer-SG 024 2345 Coding: 0000244 Shop #: WSC 73430 790 00000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-1xx-56.lbl Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C Component: Radio FO3 019 0034 Revision: 00019000 Serial number: SKZ7Z3G0140791 Coding: 0000200 Shop #: WSC 73430 790 00000 1 Fault Found: 00625 - Vehicle Speed Signal 013 - Check DTC Memory - Intermittent End ---------------------------------------------------------------------
  3. ahoj.vedeli by ste mi poradit co tam moze byt za problem? smerovky ked napojim na 12v priamo na baterku tak lekdy svietia,ale svieti mi kontrolka vypalenych ziaroviek a neidu smerovky vo zrkadlach.je to octavia combi 1,9tdipd BXE vybava ambient r.v.:2006.diky Pondilí,28,Eervenec,2014,18:22:14:10074 VCDS verze: SVO 10.6.4 Addresa 09: Centrální elektrika Labely: SVO\3C0-937-049-23-H.lbl Objednací eíslo oídící jednoky: 3C0 937 049 E HW: 3C0 937 049 E Systém a/nebo verze: Bordnetz-SG H37 1002 Kódování: 11894F011004140000110D000000000000195F0746 Eíslo dílny: WSC 73430 790 00000 Další informace: 1Z1955119A Wischer SK351 012 0401 VCID: 2B51039FF395 2 závad nalezeno. 01834 - zarovka bocniho smeroveho svetla vlevo (M18) 012 - chyba v elektr. obvodu info o závadi: Stav závad: 01101100 Priorita závad: 2 Frekvence závad: 1 Poeítadlo resetu: 18 Kilometry: 245355 km Indikace easu: 0 info o závadi: ZAP Napití: 12.00 V ZAP ZAP VYP VYP VYP 01835 - zarovka bocniho smeroveho svetla vpravo (M19) 012 - chyba v elektr. obvodu info o závadi: Stav závad: 01101100 Priorita závad: 2 Frekvence závad: 1 Poeítadlo resetu: 18 Kilometry: 245355 km Indikace easu: 0 info o závadi: ZAP Napití: 12.00 V ZAP ZAP VYP VYP VYP
  4. dadyka odpověděl na příspěvek v tématu v Motor
    ahoj.chcel by som sa opitat ci nema niekdo skusenosti s firmou Motortech.chcem si dat auto nacipovat ale proste neviem sa rozhodnut s akou firmou.dopructe prosim nejaku firmu na slovensku.najlepsie BA a okolie dakujem
  5. ahoj.mam servo TRW ale tu novsiu typu nie KOYO.ale vcera som meral aj otacky serva v na volnobehu tocy 2534otacok za minutu a prud sa pohybuje okolo 19-22 amperov.
  6. ahoj.poradte prosim mam problem so servom, dal som to na diagnostiku a vypisuje my chybu 00566 posilovac rizeni-provoz.
  7. dadyka odpověděl na Farnell's téma v Elektrika
    ahoj.mam problem s tou led diodou.ked zamknem auto neblika, ale ledka je dobra aj vodic je dobry od komfortky do dveri.neviete my nahodou poradit??diky vopred
  8. cau!mam tam original central.a s trojtlacitkovym klucom by to slo???
  9. a este jedna otazka.na vw polo r.v.:2004 9N treba tu istu komfortnu jednotku?alebo je tam ine cislo?
  10. caute! mam fabiu 1 r.v.:2006 ale ma len obicajny kluc cize nema dialkove ovladanie na central(ma central ale nie je na D.O.).chcel by som tam dat vystrelovaci kluc s ovladanim na central.dalo by sa to?keby ano tak ako?
  11. ahojte!ja ma vw polo 1,9sdi r.v.:2004.chcem sa spitat ze kolko by to malo zrat?lebo mne to vychadza na 5,8/100km myslim si ze je to dost vela na take male auto,jazdim max do 120km/h
