figus
    1
Vše zveřejněné uživatelem figus
  1. Zdravim tiez mam problem s DPF vypisuje to viacej chyb . Regeneracia nejde vyvolat ani po zadani kodu netusim kde zacat ci je vadny DPF alebo tie senzory a ako ich otestovat . Dolu vypis z vagu. Diky -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Address 01: Engine Labels: 03L-906-023-CAY.clb Control Module Part Number: 03L 906 023 AG HW: 03L 906 023 AG Component and/or Version: 1,6l R4 CR td H23 5697 Software Coding: 00114014030400080000 Work Shop Code: WSC 31414 790 00001 ASAM Dataset: EV_ECM16TDI02103L906023AG 001003 (SK35) VCID: 6BD1C39F3145 5 Faults Found: 7384 - Boost Pressure Regulation: Control Range Not Reached P0299 00 [096] - Implausible Signal Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 122157 km Date: 2065.14.04 Time: 23:07:10 7355 - Exhaust Gas Temperature Sensor; B1 S3: Malfunction P242A 00 [175] - Open Circuit Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 15 Mileage: 121677 km Date: 2064.14.30 Time: 16:21:08 7345 - Diesel Particle Filter; Differential Pressure Sensor: Short to Plus P2455 00 [040] - Upper Limit Exceeded Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 46 Mileage: 121677 km Date: 2064.14.30 Time: 16:21:08 7347 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal P2453 00 [237] - Mechanical Failure Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 3 Mileage: 121882 km Date: 2065.14.01 Time: 23:49:10 9852 - Exhaust Gas Temperature Sensor; B1 S3: Range/Performance P242B 00 [101] - Electrical Fault in Circuit Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 122343 km Date: 2065.14.09 Time: 08:01:55 Readiness: 0010 0000
