Ahojte, mam originál VCDS kabel.  Automobil: Skoda Octavia combi 81 kw DSG r.v. 2015
ako sa adaptuje spojka na DSG?
PRi adaptacii prevodovky pocujem zvuky, vsetko prebehne v poriadku, urobim testovaciu jazdu .
Pri adaptacii spojky sa nic nedeje.
V adaptaciach je moznost fast clutch adaptation... a ine.
kedze som vymenil prevodovku a nechal som iba povodnu mechatroniku, tak mam pocit, ze spojka ma vyssi tocivy moment, co sa prejavuje v trhnuti pri rozbehu.
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 048 J    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0611
   Revision: 00005005    Serial number: CU501507115569
   Coding: 0014
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 43853277CA9B285ECC-8016
No fault code found.
dakujem za radu.
Pomocí VCDS nelze provést.
tak otazka : ktorým nástrojom sa to dá? Musim navstivit origo servis?
Zjednodušene:
1)Handbrake On, Car is in Park and Ignition is on but Engine is off. (Transmission should be warmed up already before doing this)
2)Go to 02 - Electronics & Measurement Group / Basic Settings > Group 60 > Read
3)Wait for fields to display the following information: 4 - 0 - 0 and then start engine in next 10 seconds. (or it will display 255 - 7 - 0 and this means you'll have to start over again)
4)After a few seconds the fields will now display 254 - 0 - 0 which should mean that the process is complete. (Handbrake will be enough to hold car in position)
5)Exit VAGCOM and turn off engine; Basic settings are now complete.
