Publikováno Říjen 22, 20177 r Co myslíte, vadné čidlo kvality vzduchu (hlavně, že jsem byl v pátek v autorizáku na servisní prohlídce...), ale co ta sběrnice? Car: Skoda Superb Year: 2017 Body type: Estate Engine: DFEA 110 kW (150 HP) 2 l Mileage: 25185 KM --------------------------------------------------------------- 19 Gateway System description: GW MQB High Software number: 3Q0907530C Software version: 5286 Hardware number: 3Q0907530C Hardware version: 515 Serial number: 03121610520215 ODX name: EV_GatewNF ODX version: 013020 Long coding: 0B0100345F087300FB00025E880F00010001070000000000000000000000 Subsystems: System description: J367-BDMHella Software version: 9070 Hardware version: H10 Serial number: 4290702204 System description: WECHSELRICHTE Software version: 0033 Hardware version: H55 Serial number: 0311103 System description: E221__MFL-PR6 Software version: 0160 Hardware version: H02 Serial number: 000000000C0340151016 Trouble codes: U120200 - Data bus diagnostics Faulty Intermittent Date: 2017-10-20 11:12:06 Mileage: 24751 km Priority: 1 Malfunction frequency counter: 95 Unlearning counter: 140 Supply voltage, terminal 30: 13.8 V Terminal 15: Off Unknown ambient data: U140600 - Static current too high Intermittent Date: 2017-10-21 03:55:42 Mileage: 24895 km Priority: 7 Malfunction frequency counter: 2 Unlearning counter: 142 Supply voltage, terminal 30: 12.2 V Terminal 15: Off Unknown ambient data: 08 Air Conditioning System description: AC Automat Software number: 3V0907044EC Software version: 4101 Hardware number: 3V0907044EC Hardware version: H34 Serial number: 00000B00298199 ODX name: EV_ACClimaPrehVW37X ODX version: 002019 Long coding: 12010104004411011005104D0018110A Trouble codes: B10AF04 - Air quality sensor Faulty Intermittent Date: 2017-10-20 10:53:38 Mileage: 24751 km Priority: 3 Malfunction frequency counter: 10 Unlearning counter: 144 Dynamic environmental data: 26092D02867E265000FD26ED0F265000FD Upraveno Říjen 22, 20177 r od Shaarky
Listopad 10, 20177 r Autor Takže zřejmě : U140600 - Static current too high - je zřejmě způsoben klidovým odběrem proudu díky vestavěné kameře B10AF04 - Air quality sensor Faulty - vedlo k výměně čidla kvality vzduchu 5Q0907643 (údajně je na to servisní pokyn) - nicméně u mne jsem i zjistil bez diagnostiky, že ten senzor nefunguje, bylo to v kabině hodně poznat U120200 - Data bus diagnostics Faulty - aktuálně stále netuším, co to je
Listopad 11, 20177 r To poslední bude trvale připojené zařízení na diagnostické zásuvce. Upraveno Listopad 11, 20177 r od ferda25
Říjen 23, 20186 r V diagnostice Carista mi hlásí chybu 263452 (Heater & Air Conditioning). Vždy po resetu se objeví znovu. Na netu jsem nic nešel. Nevíte někdo, co by to mohl být?
Říjen 23, 20186 r Heater & air conditioning Part #: 3V0907044BP Coding: 12010104002410011005004100101002 (hex) Component: AC Automat Fault codes: 263425 Manufacturer-specific code
Listopad 21, 20186 r Tak ten senzor kvality mne taky sviti. Ovsem po zaruce. Netusi nekdo cenu cidla?
