Ahoj,
můžete mi pomoct s diagnostiku? Včera auto přestalo reagovat na plyn, zvýšilo otáčky a nejelo více než 30 km/h.
Daignostika:
                Address 01: Engine       Labels: 03C-906-056-BAG.lbl
Control Module Part Number: 03C 906 056 EB    HW: Hardware No
  Component and/or Version: MED9.5.10       G00 0144
           Software Coding: 0000071
            Work Shop Code: WSC 73430 790 00999
                      VCID: 67DA1C9B5681CA06DF-8032
3 Faults Found:
005445 - Throttle Valve Controller
               P1545 - 002 - Malfunction
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 162561 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:24:07
             Freeze Frame:
                    RPM: 720 /min
                    Load: 50.2 %
                    Speed: 0.0 km/h
                    Temperature: 62.0°C
               P1545 - 008 - Malfunction - MIL ON
             Freeze Frame:
                    Fault Status: 11101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162561 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:24:09
             Freeze Frame:
                    RPM: 880 /min
                    Load: 39.2 %
                    Speed: 0.0 km/h
                    Temperature: 62.0°C
005464 - Throttle Actuator (G186)
               P1558 - 002 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 69.0°C
Readiness: 0000 0000
Vyčistili jsme klapku, vše se zdálo OK a dnes pří jízdě auto začalo cukat.
6 Faults Found:
               P1545 - 008 - Malfunction - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162570 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:40:49
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 90.0°C
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162570 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:50:34
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
000290 - Throttle Position Sensor (G69)
               P0122 - 002 - Signal too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162570 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:51:57
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
000546 - Angle Sensor 2 for Throttle (G188)
               P0222 - 002 - Signal Too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162570 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 18:51:57
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 87.0°C
000768 - Random/Multiple Cylinder Misfire Detected
               P0300 - 001 -  - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162575 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:00:49
             Freeze Frame:
                    RPM: 2840 /min
                    Load: 43.5 %
                    Speed: 37.0 km/h
                    Temperature: 78.0°C
000769 - Cylinder 1
               P0301 - 001 - Misfire Detected - MIL ON
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 162575 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:00:49
             Freeze Frame:
                    RPM: 2840 /min
                    Load: 43.5 %
                    Speed: 37.0 km/h
                    Temperature: 78.0°C
Readiness: 0000 0101
Je to klapka na 100% nebo máme hledat jinde?
Tak to byla klapka :kol-28:
