I am sory to bother you... i hope you speak english.
i have seen you pasting some pictures about fabia power steering on forum. I do not speak cz, so i would ask you to help me..
i have a problem with our fabia 1.4 (2001) the motor turns on randomly and all the lghts are blinking
wag com reads problem n power steering sensor g250
is it faut of the sensor or is it something elese? ist it possible to repair the sensor or do i need to replace it?
what about the software you hve... with schematics.. is it possible to get it?
thank you in advance!
Miha
Chalan zo Slovinska mi poslal tento message a ja mu nedokazem na to odpovedat, bo som stary nemcur :D Moze mu dakto prosim pomoct?
Upraveno od Bemo
Maybe I´m late with my answer... But, what about cabel bunch in motor place?
A power steering sensor is a relatively easy thing to change. The sensor is lodged in the steering rack somewhere and a wire runs to a connector on the power steering pump. When the sensor breaks, the pump goes all weird and starts demanding power randomly, hence it causing the lights to go blinky - mine did this too. I bought a sensor from Ebay for about £40 and fitted it in around half an hour - was easier to do with the car on a lift though.
