alberg
Vše, co zveřejnil alberg
  1. Na 1600rpm ve 4 nebo 5 rychlostí jsem se o 320nm. To je proto, že je motor pod zatížením. Během testu, tester dělá to, co se nazývá "RAMP HOLD", která by uzamkla válečky způsobuje zatížení motoru, pak odemkne se role tak pro grafické binární ukáže nejvyšší při nízkých otáčkách (At 1600rpm in 4 or 5 speed I get about 320nm. This is because the engine is under load. During the test, the tester does what is called "RAMP HOLD" that locks the rollers causing load on the engine, then unlocks the rolls so for the graphic binary will show its highest at low rpm.)
  2. Green lines = Original Red = Reprogramed Octavia break 1.6tdi
  3. Please do comment:)
  4. Hi My 07/2010 model cannot turn corner light with blinker, anyone resolved this. They were activated with vagcom, works with turning wheel but no blinker. I have tried to do with bagcom models after mine and they also won´t work. Thanks
  5. Sorry I write in inglish, I have a 09/2010 Octavia 1.6tdi and cannot activate corner light with blinker, it works if I turn the wheels. I like also to activate 2 fog light and HHC (hill hold control) Have vagcom
