@elqbenzoit will be interesting for us, if you will report any significant oil consumption after this switch.
I just give you one (maybe) interesting information. Mobil cooperates with Shell, and actually they use their GTL product. We are talking about 50 -60% in MOBIL 1 ESP X2 0W-20. And the reason? As you mentioned - eco. Oils gained from Fischer-Tropsch synthesis have almost no sulphur. It is profitable for them to buy this product from the Qatari facility rather than to "clean" the crude oil. I have no doubts that Mobil add the best additive package while trying to meet the VW 508 specification
In case of the switch to VW 504 oil, I recommend to go with the Shell Helix Ultra ECT C2-C3 0W-30, it is cheaper in average than the competitor from Mobil, but it is loaded with roughly the same quality additive package.
Jedna (mozno) zaujimava informacia. Mobil spolupracuje so Shell, a aktualne pridavaju ich GTL produkt do svojich olejov. Pri oleji MOBIL 1 ESP X2 0W-20 je to cca 50-60%. A dovod tejto spoluprace? Eko. Oleje ziskane Fischer-Tropsch procesom neobsahuju takmer ziadnu siru. Je to financne vyhodnejsie nakupit produkt z Katarskej rafinerie ako "cistit" ropu. Nemam pochyby, ze sa Mobil snazi pridat najlepsi balik aditiv a zaroven splnat normu VW 508.
Ak nas polsky kolega chce pejst naspat na normu VW 504, odporucal som mu Shell Helix Ultra ECT C2-C3 0W-30, je vacsinou lacnejsi ako jeho konkurent od Mobil ale oba obsahuju cca rovnako kvalitny balik aditiv.
Upraveno od sk0d@
OK, I will monitor the oil consumption and let you know. Until now, I had Castrol Edge 5W-30 LL and there was practically no oil consumption - I never had to add oil having done 16k km (it was always above half full on the oil dipstick). Mějte se hezký den! :)
Myslis na mne ;) ?
Nie. Citaj hore ;)
ok :)
Hi, status update: after driving 4k km the oil level is almost full. Kuba
Sent from my Mi MIX 2 using Tapatalk
ja mam najazdene teraz 6.000 km, a idem tam vymenit olej 504.00, Longlife III.
  • 5 měsíců později...
Na mojej fabci mi dali olej 0w20 podla normy vw508.00 v autorizovanom servise pri 30tkm (rok 2017), pricom si myslim, ze od vyroby tam bol urcite olej podla normy vw504.00, ale to som uz dalej nezistoval. Pri 45tkm si robim vymenu oleja sam a davam 0w20... Pri 60tkm budem v autorizaku zistovat ci mozem prejst naspat na normu vw504.00, pokial nie, tak zostavam pri 0w20 a norme vw508.00...
Hi, I drove almost 10k (in 10 months or so) with 0w20 and the oil level were 3/4 so still not bad and close to what is was before. But I returned to the old good 5w30 for the autumn and winter, and I will probably stay with it for longer.
@elqbenzo Prosím používat, pokud možno, český jazyk. Ne všichni jsme sběhlí v cizích jazycích a navíc je to zejména pro naše uživatele. Nic na tom nemění ani fakt, že si to můžem přeložit. Dík
I think, it was good choice  :palec2:
[mention=101612]elqbenzo[/mention] Prosím používat, pokud možno, český jazyk. Ne všichni jsme sběhlí v cizích jazycích a navíc je to zejména pro naše uživatele. Nic na tom nemění ani fakt, že si to můžem přeložit. Dík
I am sorry but I do not know Czech and I didn't want to use translate tools as they usually make awful mistakes. Just wanted to share my experience with you as the biggest forum of our Czech cars.
Wysłane z mojego Mi MIX 2 przy użyciu Tapatalka
@rudasn Buďmne rádi, že tu je i nějaký cizinec, člověk co česky neumí asi nemůže psát česky a použít translator, no to už by jsme mu nemuseli rozumět nikdo...
@elqbenzo  Okay, so surely you are also using the compiler to English if you do not understand Czech, do you? That's what we're doing. Bye.
@Martab Já neměl ani tušení, že jde o cizince, já myslel, že někdo se jen tak "předvádí", tak se za poznámku omlouvám. Jinak jsem rád za každé poznatky od kohokoliv, v tomto případě o spotřebě oleje 0W-20
Já hlasuju pro ustanovení jazyka na EN - UK. Kdo se má furt s těma háčkama a čárkama na mobilu vytukávat -_-
