Publikováno Září 19, 20195 r Ahojte, mám otázku či má niekto skúsenosť s náhradou telesa filtra prevodovky za diel (od ruských expertov) s väčšou plochou (rebrovaním). Na svojej stránke tvrdia, že pomáha lepšiemu chladeniu oleja. Laicky to dáva zmysel, že olej sa tak neprehrieva a nedegraduje. Teleso_pre_DQ250 alebo druhy_odkaz Citovat Aluminum filter housing DSG-6 DQ250 VAG 02E305045 The main reason for failure of the robotic box DSG is overheating. The designers of the car also note the problem, which in the more recent DSG gearbox on the oil filter housing to wear steel corrugated aluminum, in order to improve heat dissipation. For the manufacturer, it is a cheap and easy solution. But really the best solution is to install a fully aluminum body. Coefficient of heat dissipation aluminum case above, thanks to the aluminum alloy and the ribs on the body. Improved heat dissipation from the box, thus reducing its operating temperature by 6-8 degrees. Also aluminum housing reliable native plastic (which need to be changed at every oil change). The aluminum housing is used to extend the life of the gearbox DSG.
Září 21, 20195 r a čo položka č.5 ? nemalo by toto zabezpecit ovela lepsie chladenie ako nejaka "ochrana" na teleso filtra ? vytiahnute z popisu EA288. Niesom odbornik, mozno som uplne mimo....
