fabia iii 1,2/66kw 2016
Doors / Windows / Remote:
Auto-lock doors when the ignition is switched on
      YES / *NO*
Auto-lock doors when moving
      YES / *NO*
Auto-unlock doors when key is taken out of ignition
      *YES* / NO
Auto door locking/unlocking menu in MMI
      *DISABLED* / VIEW-ONLY / ADJUSTABLE
Auto-lock when doors are closed and smart key is outside vehicle
      YES / *NO*
Pop trunk via remote
      *ENABLED* / DISABLED
Allow configuring beep when locking/unlocking
      YES / *NO*
Menu for configuring beep when locking/unlocking
      ENABLED / *DISABLED*
Beep when unlocking with remote
      YES / *NO*
Beep when locking with remote
      YES / *NO*
Use horn when locking/unlocking with remote
Duration of beep when locking/unlocking with remote
      *NORMAL* / SHORT
Lower window when door is opened (frameless doors only)
      YES / *NO*
Enable settings for opening/closing windows and sunroof
Open windows via long-press on remote (step 1 of 2)
Open windows via long-press on remote (step 2 of 2)
Close windows via long-press on remote (step 1 of 2)
Close windows via long-press on remote (step 2 of 2)
Allow configuring open/close windows with remote via infotainment
Open sunroof via long-press on remote
      YES / *NO*
Close sunroof via long-press on remote
      YES / *NO*
Sunroof action when opening via remote
      *SLIDE* / TILT
Auto fold side-view mirrors (req. power folding mirrors)
Allow configuring auto-folding mirrors in infotainment
Auto fold mirrors via…
      *LONG PRESS* / SINGLE CLICK
Allow rain closing
      YES / *NO*
Auto-close sunroof when rain is detected (must have rain sensor)
      YES / *NO*
Type of sunroof auto-close when rain is detected
      PERMANENT / *NONRECURRING*
Rain closing menu in MMI
Passive entry via smart key (driver's door)
      *YES* / NO
Passive entry via smart key (passenger's door)
      *YES* / NO
Passive entry via smart key (rear left door)
      YES / *NO*
Passive entry via smart key (rear right door)
      YES / *NO*
Passive exit via smart key (driver's door)
      *YES* / NO
Passive exit via smart key (passenger's door)
      *YES* / NO
Passive exit via smart key (rear left door)
      YES / *NO*
Passive exit via smart key (rear right door)
      YES / *NO*
Instruments / Display / Dings:
Developer menu screen in MMI via holding MENU for ~10 seconds (req. Discover Pro)
Speech dialog system / SDS (if equipped)
Instrument cluster language
      LANGUAGE 1 (USUALLY CHINESE) / LANGUAGE 2 (USUALLY CHINESE (MANDARIN)) / *LANGUAGE 3 (USUALLY CZECH)* / LANGUAGE 4 (USUALLY DANISH) / LANGUAGE 5 (USUALLY DUTCH) / LANGUAGE 7 (USUALLY ENGLISH (UK)) / LANGUAGE 6 (USUALLY ENGLISH (US)) / LANGUAGE 8 (USUALLY FINNISH) / LANGUAGE 9 (USUALLY FRENCH) / LANGUAGE 10 (USUALLY FRENCH (CANADA)) / LANGUAGE 11 (USUALLY GERMAN) / LANGUAGE 12 (USUALLY GREEK) / LANGUAGE 13 (USUALLY HUNGARIAN) / LANGUAGE 14 (USUALLY ITALIAN) / LANGUAGE 15 (USUALLY JAPANESE) / LANGUAGE 16 (USUALLY KOREAN) / LANGUAGE 17 (USUALLY POLISH) / LANGUAGE 18 (USUALLY PORTUGUESE) / LANGUAGE 19 (USUALLY PORTUGUESE (US)) / LANGUAGE 20 (USUALLY RUSSIAN) / LANGUAGE 21 (USUALLY SPANISH) / LANGUAGE 22 (USUALLY SPANISH (AMERICAS)) / LANGUAGE 23 (USUALLY SWEDISH) / LANGUAGE 24 (USUALLY TURKISH)
Driver information system (DIS) display
Efficiency program display
      *YES* / NO
Temperature display units
      *CELSIUS* / FAHRENHEIT
Distance display units
      *KM* / MILES
Speed display units
      *KM/H* / MPH
Pressure display units
      *BAR* / PSI / KPA
Volume display units
      *LITERS* / GALLONS (UK) / GALLONS (US)
Time display format
      *24H* / 12H AM/PM
Date display format
      *DD/MM/YYYY* / MM/DD/YYYY / YYYY/MM/DD
Consumption display units
      MPG (UK) / MPG (US) / *L/100KM* / KM/L
Daylight Saving Time (DST)
      OFF / *MANUAL* / EUROPE / USA / AUTOMATIC
Start screen logo (instrument cluster)
      *TYPE 1* / TYPE 2 / TYPE 3 / TYPE 4 / TYPE 5 / TYPE 6 / TYPE 7 / TYPE 8
Start screen logo (infotainment)
      NONE / TYPE 1 / *TYPE 2* / TYPE 3 / TYPE 4 / TYPE 5 / TYPE 6 / TYPE 7
User theme (infotainment)
      NONE / HIGHLINE / *HYBRID* / TYPE 3
Allow "Car" settings in MMI while car is in motion
      *YES* / NO
Allow "Tuner" settings in MMI while car is in motion
      *YES* / NO
Allow "Media" settings in MMI while car is in motion
      *YES* / NO
Allow "Phone" settings in MMI while car is in motion
      *YES* / NO
Navigation compass display
Compass display position
      RIGHT OF THE TIME DISPLAY / *LEFT OF THE TIME DISPLAY*
Refuel quantity in MFD
Display cylinder shut-off
      *YES* / NO
Speed warning at 120 km/h (75 mph)
      YES / *NO*
Gauge needle sweep at startup
      *YES* / NO
Gauge needles lit even when headlights are off
      *YES* / NO
Gauge scales lit even when headlights are off
      *YES* / NO
Show digital speed in dashboard
      *YES* / NO
Instrument cluster LCD background
      DEFAULT / CARBON FIBER / BACKGROUND 2 / BACKGROUND 3 / *NOT AVAILABLE*
Telephone menu display
Battery charge display (req. instrument cluster support)
Seat belt warning
Seat belt warning type
      DISABLED / US/CANADA STYLE / *EURO STYLE* / EURO STYLE 2 / EURO STYLE 3
Ding when key is left in ignition
      OFF / *DRIVER'S DOOR* / ALL DOORS
Lap timer (if equipped)
Oil temperature display
Allow enabling oil temperature display via MMI
Ambient temperature display
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
      1 FLASH / 2 FLASHES / *3 FLASHES*
Park distance visualization (if equipped)
      *YES* / NO
Show "Follow traffic regulations" disclaimer in infotainment
      YES / *NO*
Driving school mode (step 1 of 3)
Driving school mode (step 2 of 3)
Driving school mode (step 3 of 3)
Lights:
Daytime running lights
Daytime running lights (DRL) brightness when headlights are on (left)
      10.0
Daytime running lights (DRL) brightness when headlights are on (right)
      10.0
Daytime running lights (DRL) brightness when turn signal is on (left)
      0.0
Daytime running lights (DRL) brightness when turn signal is on (right)
      0.0
Allow configuring daytime running lights via dash display
      *YES* / NO
Daytime running lights on only when switch is set to AUTO
      YES / *NO*
Parking light activates daytime running lights (DRL)
      YES / *NO*
Daytime running lights (DRL) activate parking light
      YES / *NO*
Turn off right daytime running lights ("wink") when turn signal is on (step 1 of 2)
Turn off left daytime running lights ("wink") when turn signal is on (step 1 of 2)
Turn off daytime running lights when parking brake is on
      YES / *NO*
Reverse light brightness (left)
      100.0
Reverse light brightness (right)
      100.0
Auto headlights activation threshold
      LOW / *NORMAL* / HIGH
Auto turn on headlights when driving above 140 kph / 90 mph
      YES / *NO*
Turn off front fog lights when high beams are on
      YES / *NO*
Coming-home lights mode
      MANUAL: FLASH HIGH BEAMS TO ACTIVATE / *AUTOMATIC: WHEN IT'S DARK (REQ. AUTO HEADLIGHTS)* / DISABLED
Coming-home lights trigger
      WHEN IGNITION IS SWITCHED OFF / *WHEN DOOR IS OPENED*
Coming-home lights use…
      *LOW BEAMS* / FOG LIGHTS
Coming-home lights duration
      10.0
Enable flashing rear fogs along with flash-to-pass
Flash rear fogs along with flash-to-pass when headlights are off
Flash rear fogs along with flash-to-pass when headlights are on
Left cornering light (using fog light)
      OFF / *ON*
Right cornering light (using fog light)
      OFF / *ON*
Cornering lights minimum activation speed
      0.0
Cornering lights maximum activation speed
      40.0
Turn on fog lights on reverse
Flash brake lights in emergency stopping
      *YES* / NO
Flash brake lights in emergency stopping (Phase 2)
      YES / *NO*
Flash hazard lights in emergency stopping
      *YES* / NO
Left inner brake light (step 1 of 2)
Left inner brake light (step 2 of 2)
Right inner brake light (step 1 of 2)
Right inner brake light (step 2 of 2)
License plate bulb check (step 1 of 2)
License plate bulb check (step 2 of 2)
Other:
Disable auto start/stop system (method A)
      YES (12.1V LIMIT) / NO (8.0V LIMIT) / *NO (7.6V LIMIT)*
Disable auto start/stop system (method B)
      YES / *NO*
Microphone sensitivity
      4.0
Fuel tank capacity calibration
      -12.8
Hill hold assist (if equipped)
Hill start assist disengagement
      *EARLY* / NORMAL / LATE
Hill start assist activation threshold
      3.0
Extended electronic differential lock strength (XDS)
      *OFF* / NORMAL / WEAK / MEDIUM / HIGH
Headlight washers (if equipped)
Additional 'tear' wipe after windshield washer use
Additional 'tear' wipe after rear window washer use
      YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
      *YES* / NO
Indirect TPMS system (step 1 of 3)
Indirect TPMS system (step 2 of 3)
Indirect TPMS system (step 3 of 3)
Deactivate active exhaust flap (where applicable)
      *YES* / NO
Wi-Fi hotspot (step 1 of 3)
Wi-Fi hotspot (step 2 of 3)
Wi-Fi hotspot (step 3 of 3)
UPnP/DLNA
Na ENABLED, ale i tak u FIII bude fungovat maximálně řidičovo.
před 24 minutami, Martab napsal:
toho som sa bal takze u mna to nefunguje
On 7/24/2018 at 9:36 AM, jandis said:
>Sklopení spolujezdcovo zrcátka při zpátečce funguje jen u sedadel s pamětí.
AHA...grrr
>Zavření oken při dešti funguje, asi jsi vybral špatnou možnost. Nebo nemás dešťový senzor.
Senzor mám... nemyslí sa tým len strešné okno? (to nemám)
OK, dík
[mention=100625]zajko65[/mention]
Ano, lze nastavit i u vozidel bez továrního alarmu
Zavření oken při dešti lze pouze do určitého MR. Zainteresovaní určitě uvedou správný rok. Každopádně na MR2017 nefunguje.
Dešťový senzor nemám (Fab. 3 MR2018) a po nastavení v Caristě se okno po přidržení tlačítka na dálce otevřelo a po dlouhém stisknutí zamykacího tlačítka zavřelo. Bohužel druhý den už to nefungovalo, nebo jen někdy. Myslím, že to v Caristě ještě není stoprocentně funkční (alespoň ne u F3). Nedávno jsem to zkoušel ve v.3.7 beta-44 a to už mi nešlo vůbec :(
Editováno: , autor: Lupen_cz
Beta 3.7-44 - Fabia 3 Ambi. 2016 Možnost odstranění chybové hlášky po instalaci LED do osvětlení SPZ. Funguje, chybu nehlásí. Paráda.
před 19 hodinami, LukášCBR napsal:
Ja mám O3 2014 a samo od seba to nefunguje. Cez caristu som povolil v MIB polozku menu, , zatrhnem si to tam v MIB ale i tak to nefunguje.
Tak som zisťoval prečo mi nejde sklopenie spolujazdcovho zrkadla pri zaradení spiatočky a zistil som že
Remember position when lowering passenger-side mirror in reverse gear (step 1 of 2)
a Remember position when lowering passenger-side mirror in reverse gear (step 2 of 2)
to spoľahlivo zabijú.
Ak to tam nezapnem, tak to funguje, ale zas to nevráti do pôvodnej polohy.... A tuším to zafunguje len raz po zapnutí funkcie. Potom už nie.
O3 2014
Editováno: , autor: kluvi
Zdar chlapci jak je to na Supu2 pokud dám třeba LED obrysové nebo do SPZ koukám že ani beta neumí nastavit toleranci "check bulb".
Nemá ani nastavení intervalu po kterém začne ostřik světel....
Nevíte, jestli napájení pro zadní světla se mění, pokud bych vyměnil na LED svícení?
No nechtěl bych tu aplikaci platit, když to v podstatě nic neumí, všechny komfortní funkce jsou nastaveny z výroby, jen nějaké drobnosti se dají nastavit třeba zbytečně Corner/DRL svítí skoro na plno (92%). TCS a brzdy a to je tak zhruba všechno.
No nicméně, když jsem tady na to koukal tak žádné řešení pro instalaci Caristy, takže dávám do placu legální a oficiální postup.
Stáhněte poslední Beta Caristu, v poslední verzi už nejsou skoro vůbec žádné možnosti a Caristu crack nepoužívejte chybí in-app purchase.
Dejte zaplatit, pokud tam bude ještě 7denní zkušební tak vyberte, aktivuje se i na jiných zařízeních s Google pay.
Vyzkoušejte, nastavte, zrušte předplatné. Celá sranda. Pochybuju, že kromě testování tam budete v budoucnu něco nastavovat.....
Mám dva dotazy. Půjde mě na f2 2010 to sklopení zrcátka spolujezdce při zařazení zpátečky? Elektricky nastavované zrcátka mám.
A kámoš má Citroën C6 či něco podobného a rád by nastavil češtinu do infotaimentu. To carista asi nedokáže nějak odblokovat a nejspíš tam ani čeština není že? Nebo carista je jen na vw group?
