Červenec 26, 20187 r ok Suchy 181, som rad ze funguje :-) P.S. cez Total Commander som si skopiroval Carista (nainstalovana a patchnuta) medzi fotky v mobile, nasledne sem na forum.
Červenec 26, 20187 r Autor Sorry hosi, musite si poradit bezomna, je tu kopec sikovnych ludi co pridavaju aktualne verzie. Tymto im moc dakujem.
Červenec 27, 20187 r fabia iii 1,2/66kw 2016 Doors / Windows / Remote:Auto-lock doors when the ignition is switched on YES / *NO*Auto-lock doors when moving YES / *NO*Auto-unlock doors when key is taken out of ignition *YES* / NOAuto door locking/unlocking menu in MMI *DISABLED* / VIEW-ONLY / ADJUSTABLEAuto-lock when doors are closed and smart key is outside vehicle YES / *NO*Pop trunk via remote *ENABLED* / DISABLEDAllow configuring beep when locking/unlocking YES / *NO*Menu for configuring beep when locking/unlocking ENABLED / *DISABLED*Beep when unlocking with remote YES / *NO*Beep when locking with remote YES / *NO*Use horn when locking/unlocking with remote ENABLED / *DISABLED*Duration of beep when locking/unlocking with remote *NORMAL* / SHORTLower window when door is opened (frameless doors only) YES / *NO*Enable settings for opening/closing windows and sunroof ENABLED / *DISABLED*Open windows via long-press on remote (step 1 of 2) ENABLED / *DISABLED*Open windows via long-press on remote (step 2 of 2) ENABLED / *DISABLED*Close windows via long-press on remote (step 1 of 2) ENABLED / *DISABLED*Close windows via long-press on remote (step 2 of 2) ENABLED / *DISABLED*Allow configuring open/close windows with remote via infotainment *DISABLED* / VIEW-ONLY / ADJUSTABLEOpen sunroof via long-press on remote YES / *NO*Close sunroof via long-press on remote YES / *NO*Sunroof action when opening via remote *SLIDE* / TILTAuto fold side-view mirrors (req. power folding mirrors) ENABLED / *DISABLED*Allow configuring auto-folding mirrors in infotainment ENABLED / *DISABLED*Auto fold mirrors via… *LONG PRESS* / SINGLE CLICKAllow rain closing YES / *NO*Auto-close sunroof when rain is detected (must have rain sensor) YES / *NO*Type of sunroof auto-close when rain is detected PERMANENT / *NONRECURRING*Rain closing menu in MMI ENABLED / *DISABLED*Passive entry via smart key (driver's door) *YES* / NOPassive entry via smart key (passenger's door) *YES* / NOPassive entry via smart key (rear left door) YES / *NO*Passive entry via smart key (rear right door) YES / *NO*Passive exit via smart key (driver's door) *YES* / NOPassive exit via smart key (passenger's door) *YES* / NOPassive exit via smart key (rear left door) YES / *NO*Passive exit via smart key (rear right door) YES / *NO*Instruments / Display / Dings:Developer menu screen in MMI via holding MENU for ~10 seconds (req. Discover Pro) ENABLED / *DISABLED*Speech dialog system / SDS (if equipped) ENABLED / *DISABLED*Instrument cluster language LANGUAGE 1 (USUALLY CHINESE) / LANGUAGE 2 (USUALLY CHINESE (MANDARIN)) / *LANGUAGE 3 (USUALLY CZECH)* / LANGUAGE 4 (USUALLY DANISH) / LANGUAGE 5 (USUALLY DUTCH) / LANGUAGE 7 (USUALLY ENGLISH (UK)) / LANGUAGE 6 (USUALLY ENGLISH (US)) / LANGUAGE 8 (USUALLY FINNISH) / LANGUAGE 9 (USUALLY FRENCH) / LANGUAGE 10 (USUALLY FRENCH (CANADA)) / LANGUAGE 11 (USUALLY GERMAN) / LANGUAGE 12 (USUALLY GREEK) / LANGUAGE 13 (USUALLY HUNGARIAN) / LANGUAGE 14 (USUALLY ITALIAN) / LANGUAGE 15 (USUALLY JAPANESE) / LANGUAGE 16 (USUALLY KOREAN) / LANGUAGE 17 (USUALLY POLISH) / LANGUAGE 18 (USUALLY PORTUGUESE) / LANGUAGE 19 (USUALLY PORTUGUESE (US)) / LANGUAGE 20 (USUALLY RUSSIAN) / LANGUAGE 21 (USUALLY SPANISH) / LANGUAGE 22 (USUALLY SPANISH (AMERICAS)) / LANGUAGE 23 (USUALLY SWEDISH) / LANGUAGE 24 (USUALLY TURKISH)Driver information system (DIS) display *ENABLED* / DISABLEDEfficiency program display *YES* / NOTemperature display units *CELSIUS* / FAHRENHEITDistance display units *KM* / MILESSpeed display units *KM/H* / MPHPressure display units *BAR* / PSI / KPAVolume display units *LITERS* / GALLONS (UK) / GALLONS (US)Time display format *24H* / 12H AM/PMDate display format *DD/MM/YYYY* / MM/DD/YYYY / YYYY/MM/DDConsumption display units MPG (UK) / MPG (US) / *L/100KM* / KM/LDaylight Saving Time (DST) OFF / *MANUAL* / EUROPE / USA / AUTOMATICStart screen logo (instrument cluster) *TYPE 1* / TYPE 2 / TYPE 3 / TYPE 4 / TYPE 5 / TYPE 6 / TYPE 7 / TYPE 8Start screen logo (infotainment) NONE / TYPE 1 / *TYPE 2* / TYPE 3 / TYPE 4 / TYPE 5 / TYPE 6 / TYPE 7User theme (infotainment) NONE / HIGHLINE / *HYBRID* / TYPE 3Allow "Car" settings in MMI while car is in motion *YES* / NOAllow "Tuner" settings in MMI while car is in motion *YES* / NOAllow "Media" settings in MMI while car is in motion *YES* / NOAllow "Phone" settings in MMI while car is in motion *YES* / NONavigation compass display ENABLED / *DISABLED*Compass display position RIGHT OF THE TIME DISPLAY / *LEFT OF THE TIME DISPLAY*Refuel quantity in MFD ENABLED / *DISABLED*Display cylinder shut-off *YES* / NOSpeed warning at 120 km/h (75 mph) YES / *NO*Gauge needle sweep at startup *YES* / NOGauge needles lit even when headlights are off *YES* / NOGauge scales lit even when headlights are off *YES* / NOShow digital speed in dashboard *YES* / NOInstrument cluster LCD background DEFAULT / CARBON FIBER / BACKGROUND 2 / BACKGROUND 3 / *NOT AVAILABLE*Telephone menu display *ENABLED* / DISABLEDBattery charge display (req. instrument cluster support) ENABLED / *DISABLED*Seat belt warning ENABLED / *DISABLED*Seat belt warning type DISABLED / US/CANADA STYLE / *EURO STYLE* / EURO STYLE 2 / EURO STYLE 3Ding when key is left in ignition OFF / *DRIVER'S DOOR* / ALL DOORSLap timer (if equipped) ENABLED / *DISABLED*Oil temperature display *ENABLED* / DISABLEDAllow enabling oil temperature display via MMI *ENABLED* / DISABLEDAmbient temperature display *ENABLED* / DISABLEDLane-change turn signal auto-flasher *ENABLED* / DISABLEDLane-change turn signal auto-flasher count 1 FLASH / 2 FLASHES / *3 FLASHES*Park distance visualization (if equipped) *YES* / NOShow "Follow traffic regulations" disclaimer in infotainment YES / *NO*Driving school mode (step 1 of 3) ENABLED / *DISABLED*Driving school mode (step 2 of 3) ENABLED / *DISABLED*Driving school mode (step 3 of 3) *ENABLED* / DISABLEDLights:Daytime running lights *ENABLED* / DISABLEDDaytime running lights (DRL) brightness when headlights are on (left) 10.0Daytime running lights (DRL) brightness when headlights are on (right) 10.0Daytime running lights (DRL) brightness when turn signal is on (left) 0.0Daytime running lights (DRL) brightness when turn signal is on (right) 0.0Allow configuring daytime running lights via dash display *YES* / NODaytime running lights on only when switch is set to AUTO YES / *NO*Parking light activates daytime running lights (DRL) YES / *NO*Daytime running lights (DRL) activate parking light YES / *NO*Turn off right daytime running lights ("wink") when turn signal is on (step 1 of 2) *ENABLED* / DISABLEDTurn off left daytime running lights ("wink") when turn signal is on (step 1 of 2) *ENABLED* / DISABLEDTurn off daytime running lights when parking brake is on YES / *NO*Reverse light brightness (left) 100.0Reverse light brightness (right) 100.0Auto headlights activation threshold LOW / *NORMAL* / HIGHAuto turn on headlights when driving above 140 kph / 90 mph YES / *NO*Turn off front fog lights when high beams are on YES / *NO*Coming-home lights mode MANUAL: FLASH HIGH BEAMS TO ACTIVATE / *AUTOMATIC: WHEN IT'S DARK (REQ. AUTO HEADLIGHTS)* / DISABLEDComing-home lights trigger WHEN IGNITION IS SWITCHED OFF / *WHEN DOOR IS OPENED*Coming-home lights use… *LOW BEAMS* / FOG LIGHTSComing-home lights duration 10.0Enable flashing rear fogs along with flash-to-pass ENABLED / *DISABLED*Flash rear fogs along with flash-to-pass when headlights are off ENABLED / *DISABLED*Flash rear fogs along with flash-to-pass when headlights are on ENABLED / *DISABLED*Left cornering light (using fog light) OFF / *ON*Right cornering light (using fog light) OFF / *ON*Cornering lights minimum activation speed 0.0Cornering lights maximum activation speed 40.0Turn on fog lights on reverse ENABLED / *DISABLED*Flash brake lights in emergency stopping *YES* / NOFlash brake lights in emergency stopping (Phase 2) YES / *NO*Flash hazard lights in emergency stopping *YES* / NOLeft inner brake light (step 1 of 2) ENABLED / *DISABLED*Left inner brake light (step 2 of 2) ENABLED / *DISABLED*Right inner brake light (step 1 of 2) ENABLED / *DISABLED*Right inner brake light (step 2 of 2) ENABLED / *DISABLED*License plate bulb check (step 1 of 2) *ENABLED* / DISABLEDLicense plate bulb check (step 2 of 2) *ENABLED* / DISABLEDOther:Disable auto start/stop system (method A) YES (12.1V LIMIT) / NO (8.0V LIMIT) / *NO (7.6V LIMIT)*Disable auto start/stop system (method YES / *NO*Microphone sensitivity 4.0Fuel tank capacity calibration -12.8Hill hold assist (if equipped) *ENABLED* / DISABLEDHill start assist disengagement *EARLY* / NORMAL / LATEHill start assist activation threshold 3.0Extended electronic differential lock strength (XDS) *OFF* / NORMAL / WEAK / MEDIUM / HIGHHeadlight washers (if equipped) ENABLED / *DISABLED*Additional 'tear' wipe after windshield washer use ENABLED / *DISABLED*Additional 'tear' wipe after rear window washer use YES / *NO*Auto-enable rear wiper when front wipers on and reverse gear engaged *YES* / NOIndirect TPMS system (step 1 of 3) *ENABLED* / DISABLEDIndirect TPMS system (step 2 of 3) *ENABLED* / DISABLEDIndirect TPMS system (step 3 of 3) *ENABLED* / DISABLEDDeactivate active exhaust flap (where applicable) *YES* / NOWi-Fi hotspot (step 1 of 3) ENABLED / *DISABLED*Wi-Fi hotspot (step 2 of 3) ENABLED / *DISABLED*Wi-Fi hotspot (step 3 of 3) *ENABLED* / DISABLEDUPnP/DLNA *ENABLED* / DISABLED
Červenec 27, 20187 r Nevie niekto ktore polozky mam odskurtnut na stahovanie okna dialkovym Dik Upraveno Červenec 27, 20187 r od Suchy 181
Červenec 27, 20187 r Open windows via long-press on remote (step 1 of 2) ENABLED / *DISABLED*Open windows via long-press on remote (step 2 of 2) ENABLED / *DISABLED*Close windows via long-press on remote (step 1 of 2) ENABLED / *DISABLED*Close windows via long-press on remote (step 2 of 2) ENABLED / *DISABLED* Na ENABLED, ale i tak u FIII bude fungovat maximálně řidičovo.
Červenec 27, 20187 r před 24 minutami, Martab napsal: Open windows via long-press on remote (step 1 of 2) ENABLED / *DISABLED*Open windows via long-press on remote (step 2 of 2) ENABLED / *DISABLED*Close windows via long-press on remote (step 1 of 2) ENABLED / *DISABLED*Close windows via long-press on remote (step 2 of 2) ENABLED / *DISABLED* Na ENABLED, ale i tak u FIII bude fungovat maximálně řidičovo. toho som sa bal takze u mna to nefunguje
Červenec 27, 20187 r Konečně funkční zatroubení při zamknuti/odemknutí vozidla. Alarm využívající klakson stále nefunkční.
Červenec 28, 20187 r On 7/24/2018 at 9:36 AM, jandis said: >Sklopení spolujezdcovo zrcátka při zpátečce funguje jen u sedadel s pamětí. AHA...grrr >Zavření oken při dešti funguje, asi jsi vybral špatnou možnost. Nebo nemás dešťový senzor. Senzor mám... nemyslí sa tým len strešné okno? (to nemám) OK, dík
Červenec 28, 20187 r [mention=100625]zajko65[/mention] Ano, lze nastavit i u vozidel bez továrního alarmu Zavření oken při dešti lze pouze do určitého MR. Zainteresovaní určitě uvedou správný rok. Každopádně na MR2017 nefunguje.
Červenec 28, 20187 r V 27. 7. 2018 na 13:41, Suchy 181 napsal: toho som sa bal takze u mna to nefunguje Ma niečo spoločné dažďové senzor s diaľkovým zatvorenie alebo otvorením akna :sofer:
Červenec 28, 20187 r Dešťový senzor nemám (Fab. 3 MR2018) a po nastavení v Caristě se okno po přidržení tlačítka na dálce otevřelo a po dlouhém stisknutí zamykacího tlačítka zavřelo. Bohužel druhý den už to nefungovalo, nebo jen někdy. Myslím, že to v Caristě ještě není stoprocentně funkční (alespoň ne u F3). Nedávno jsem to zkoušel ve v.3.7 beta-44 a to už mi nešlo vůbec Upraveno Červenec 28, 20187 r od Lupen_cz
Červenec 29, 20187 r Beta 3.7-44 - Fabia 3 Ambi. 2016 Možnost odstranění chybové hlášky po instalaci LED do osvětlení SPZ. Funguje, chybu nehlásí. Paráda.
Červenec 29, 20187 r Kde nájdem odstránenie chybovej hlášky ? Nejako to neviem nájsť. Golf MK6 2011 Verzia beta 47. Ďakujem
Červenec 29, 20187 r před 19 hodinami, LukášCBR napsal: [mention=100625]zajko65[/mention] Zavření oken při dešti lze pouze do určitého MR. Zainteresovaní určitě uvedou správný rok. Každopádně na MR2017 nefunguje. Ja mám O3 2014 a samo od seba to nefunguje. Cez caristu som povolil v MIB polozku menu, , zatrhnem si to tam v MIB ale i tak to nefunguje.
Červenec 29, 20187 r Tak som zisťoval prečo mi nejde sklopenie spolujazdcovho zrkadla pri zaradení spiatočky a zistil som že Remember position when lowering passenger-side mirror in reverse gear (step 1 of 2) a Remember position when lowering passenger-side mirror in reverse gear (step 2 of 2) to spoľahlivo zabijú. Ak to tam nezapnem, tak to funguje, ale zas to nevráti do pôvodnej polohy.... A tuším to zafunguje len raz po zapnutí funkcie. Potom už nie. O3 2014 Upraveno Červenec 29, 20187 r od kluvi
Červenec 29, 20187 r Zdar chlapci jak je to na Supu2 pokud dám třeba LED obrysové nebo do SPZ koukám že ani beta neumí nastavit toleranci "check bulb". Nemá ani nastavení intervalu po kterém začne ostřik světel.... Nevíte, jestli napájení pro zadní světla se mění, pokud bych vyměnil na LED svícení? No nechtěl bych tu aplikaci platit, když to v podstatě nic neumí, všechny komfortní funkce jsou nastaveny z výroby, jen nějaké drobnosti se dají nastavit třeba zbytečně Corner/DRL svítí skoro na plno (92%). TCS a brzdy a to je tak zhruba všechno. No nicméně, když jsem tady na to koukal tak žádné řešení pro instalaci Caristy, takže dávám do placu legální a oficiální postup. Stáhněte poslední Beta Caristu, v poslední verzi už nejsou skoro vůbec žádné možnosti a Caristu crack nepoužívejte chybí in-app purchase. Dejte zaplatit, pokud tam bude ještě 7denní zkušební tak vyberte, aktivuje se i na jiných zařízeních s Google pay. Vyzkoušejte, nastavte, zrušte předplatné. Celá sranda. Pochybuju, že kromě testování tam budete v budoucnu něco nastavovat.....
Červenec 30, 20187 r Mám dva dotazy. Půjde mě na f2 2010 to sklopení zrcátka spolujezdce při zařazení zpátečky? Elektricky nastavované zrcátka mám. A kámoš má Citroën C6 či něco podobného a rád by nastavil češtinu do infotaimentu. To carista asi nedokáže nějak odblokovat a nejspíš tam ani čeština není že? Nebo carista je jen na vw group?
Červenec 30, 20187 r Carista lze použít na vozidla mimo VW group. Toyota, Lexus, Nissan, Renault, Dacia atp.
Červenec 30, 20187 r Akorát tu češtinu mu nenastavíš, protože to není jen věc odblokování, ale to auto ji nemá nahranou.
Červenec 30, 20187 r Aha ok takže by teoreticky měl fungovat můj bluethoot konektor i na jeho auto když mě jede na f2 2010 a on má asi 2007 R. V. Že bych mu zkusil něco doinstalovat třeba jestli to ještě jde.
Červenec 30, 20187 r Tady jsou podporované auta: https://caristaapp.com/vehicles nesetí to uplně přesně, ale aspoň pro informaci. Jinak adaptér je stejný pro všechny podporované auta, tedy pokud funguje ve Fábii, bude fungovat i v jiném autě a záleží jen na tom co umí daná aplikace.
Červenec 30, 20187 r před 23 hodinami, Haig napsal: To Purplesticks: Ďakujem. Vo verzií 3.7 beta 47 to nemám. Je to problém len u mňa, že to nepodporuje moja RJ ? (Golf 6 2011)
