Bolero, Amundsen, Columbus MBI2 firmware update MST2_EU_SK_ZR_P0478T
Potvrdzujem funkcnost :) Aktualizovane z 0367 (Amundsen, Rapid MR17)
Vdaka za firmware.
Mohu se zeptat, zda jde o poslední softwarovou verzi MIB2? Od MR 21 by kromě fabie měl být v ostatních modelech MIB3.
Co viem tak toto je posledná vezria.
Pro mib2std.
A mohu se zeptat v čem je tento poslední firmware lepší?
Hello !
First of all, sorry my message is in English (I'm french).
I'm currently in 363 in a Skoda Fabia III 2017. My unit does not have navigation feature (Bolero).
118565202-2988196494642854-3157375459992118581070-734418207114531-21330995731821
I downloaded firmware MST2_EU_SK_ZR_P0367T and MST2_EU_SK_ZR_P0478T.
Should I go to 367 and after to 478 like @Vladimir Petras ?
I would like to know if there is any risk to do the update ? I see few messages on Seat forum speaking of loosing full link  (Android auto etc) licence. Others say that we need to patch our unit before flash. Maybe @Jaroslavbielicky or @Vladimir Petras you could answer me ?
Just like @ondra.rs, I'm interested about the changelog. Is it worth to flash our unit ?
Thanks a lot for my questions and the language.
@valentintintin
Hi, you can update only to 0367 (officially from 2xx to 2xx, from 3xx to 3xx, from 4xx to 4xx) without any modding. If you want update to bigger version 03xx -> 04xx you have to patch your unit, edit firmware and than you could update to 0478. But on bolero (without navigation) you have to disassembly your unit, and do some HW tricks (read memory via PC). And of course, after update all installed features working correctly. I had bought Smart Link before update, and after update it's working without reactivation needed.
If you are interested PM me.
BTW on units with navigation (2 SD slots) it's more simple. You don't need to do any HW tricks, it's just SD card method. Even activation of SWAP / FEC codes (Android Auto, Apple Car Play, Mirror Link...).
And of course there is risk. If you don't have correct solution you can brick unit (but is possible to do recovery, but it's again HW tricks). And about changes, there is grid menu, some transition animations and support of Virtual Cockpit. But update to 0367 is no problem, only you have to be sure that your battery is in good condition and will not discharge during update, or keep engine running or connect to charger during update. Update process takes about 20 minutes with CLASS 10 SD card.
On seat forum you probably read about Android Auto / Apple Carplay were disappeared from menu during update from 0245 >0330 > 0346. That items can be simply enabled with VCDS, but it's only during SEAT update 0245 >0330 > 0346. It's not happening during Skoda update.
SK:
Mozes updatovat len na 0367 (oficialne z 2xx na 2xx, z 3xx na 3xx, z 4xx na 4xx). Ak chces updatovat na vyssiu verziu 03xx -> 04xx musis patchnut jednotku a upravit firmware, a potom vies aktualizovat na 0478. Ale pri bolero (bez navigacie) musis rozobrat jednotku a spravit HW zasah (precitat pamat cez PC). Po aktualizacii samozrejme vsetky nainstalovane funckie funguju bez problemov. Ja som mal kupeny Smart Link pred aktualizaciou, a po aktualizacii funguje bez potreby reaktivacie.
Ak mas zaujem napis mi spravu.
Mimochodom na jednotkach s navigaciou (2 SD sloty) je to o mnou jednoduchsie. Nemusis robit ziaden HW zasah, je to ciste metoda s SD kartou. Taktiez aj aktivacia SWAP / FEC kodov (Android Auto, Apple Car Play, Mirror Link...).
A samozrejme su tu rizika. Ak nemas spravne riesenie mozes bricknut jednotku (je mozne spravit obnovu, ale je to zas HW zasah). A ohladom zmien, je nove dlazdicove menu, nejake animacie prechodov a podpora Virtual Cockpitu. Ale update na 0367 nie je problem, akurat baterka musi byt v dobrej kondicii, aby sa nevybila pocas updatu, alebo nechaj bezat motor alebo pripoj na nabijacku pred updatom. Aktualizacia trva cca 20 minut s pouzitim CLASS 10 SD karty.
Na seat fore si pravdepodobne cital ze Android Auto / Apple Carplay zmyzli z meno pocas updatu z 0245 >0330 > 0346. Tieto polozky sa daju jednoducho znova zapnut cez VCDS, ale to sa tyka len SEAT updatu 0245 >0330 > 0346. Nenastava to pri Skoda update.
Upraveno od wlado93
Hi !
Thanks a lot for your answer @wlado93. There should be more people wich inform in details about the update of our unit !
As a developper, I love when everything is up to date so I'll go to 367 for the beginning :)
Do you think it is worth to do all that complicated things to go to 478 for just UI changes ? If yes, I could consider doging it.
@valentintintin
I love when everything is up to date too :) I am not sure if this steps for Bolero is worth to you if you have activated smartlink yet. But if you want to have new menu and you are good in HW then why not...
SK:
Tiez mam rad vsetko aktualne. Nie som si isty ci sa ti oplati robit tieto kroky pri Boleru ked uz mas aktivovany smartlink. Ale ak chces mat nove menu a ide ti to s HW tak preco nie...
Upraveno od wlado93
@wlado93
I don't know the required level for your HW mod. But, I do some electronics things (solder do not worry me). I'm currently reversing the convenience data bus of my car in order to create a remote control for handicapped people (my girlfriend in my case). The project is in good state (headlights calls, turning indicator, wiper controled by my computer presently).
Regarding to this, I'm curious about what I need to do to patch my unit :) You can MP me if you want.
Po update firmware radia je třeba zrušit chybu v 5F......jednoduchý postup
Ano, nakodovat XOR hodnotu. Zvladne to car scanner jednym tuknutim, netreba nic pocitat. Ale aj bez kodovania vsetko funguje, akurat sa neda vymazat chyba 1555, pozostatok po update.
prosim ta kde v car scanner appke sa to da nastavit?  predpokladam long coding 2. 5F. Electronic Information System 1????? alebo nejak inak,
akurat mam mib1 0435 bolero a chcem aktualizovat na 0490. bude vsetko spravne fungovat aj bez 5F codovania?
@Fuco je to v 5F adaptation, confirmation of installation change
Ano vsetko funguje aj bez kodovania, akurat sa neda zmazat chyba 1555 ktora sa vytvori po aktualizacii.
Dakujem ti za pomoc
trvalo mi to ale nakoniec som to naozaj nasiel a je to  aj v CarScanner.  :)
pre inych co to nahodou budu citat toto vlakno v CarScanner je to v CODING- MULTIMEDIA -  "confirmation of installation change"  a stlacite confirm a je to.
Upraveno od Fuco
@wlado93 ahoj, prosim ťa mohol by si sa mi ozvať na mail: lukas.centes@gmail.com, prípadne na FB s tým istým menom? Kúpil som Superba 3 a chcel by som si aktualizovať amundsen no mam tam verziu 0245...
Ak by si mi vedel pomôcť a bol by si ochotný tak sa prosím ozvi.
Ďakujem
Upraveno od lukascentes
Zdravím,
máte někdo k dispozici tento update i na S3?
Díky moc.
V 30. 1. 2021 na 14:05, Dominikk19 napsal:
Díky za info, nějaké zkušenosti s aktualizací?
Díky.
Nějaký aktualní odkaz ke staženi?děkuji
V 7. 7. 2020 na 20:23, jaroslavbielicky napsal:
ahoj Jaro  prosim aky je postup na instalciu FW ?staci rozbalit  RAR subor na sd kartu a vlozit do  sd slotu radia? .dakujem
V 2. 9. 2020 na 16:53, wlado93 napsal:
@valentintintin
SK:
Hi.Please where can i download  this  FW 0367 any link pls!thnx
Ahoj!Prosim kde bz som stiahol FW 0367 prosim o daky link ,stranku .dakujem
