01314 - Engine Control Module - Elektrika - ŠKODA Forum - SKODAHOME.cz Přejít na obsah
lat01ji
Zdravím,
uvedený chybový kód 01314 se mi objevuje u více jednotek :
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004202407
Coding: 118C0F030004140000110D000000000000397F0740
Shop #: WSC 73430 790 00000
Part No: 1Z1 955 119 A
Component: Wischer SK351 012 0401
Coding: 00063477
Shop #: WSC 73430
1 Fault Found:
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 69847 km
Time Indication: 0
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 812 B HW: 1Z0 920 812 B
Component: KOMBIINSTRUMENT VD1 1610
Revision: V1610036 Serial number: SKZ7Z0F3683338
Coding: 0003101
Shop #: WSC 25208 260 00887
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 69847 km
Time Indication: 0
Date: 2000.00.00
Time: 17:41:17
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065171987
Coding: 3D3F074007002302
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 145
Mileage: 69847 km
Time Indication: 0
Date: 2000.00.00
Time: 17:41:18
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.067 H07 1806
Shop #: WSC 02069 000 90108
1 Fault Found:
Freeze Frame:
Mileage: 69690 km
Temperature: 35.0°C
Voltage: 11.10 V
Voltage: 10.90 V
Ve VIS je to něco s jednotkou motoru ( problémy s chodem motoru nemám ).
Tak nevím čím to je, čím to je, co ta chyba znamená.
Díky za reakce.
  • o 3 roky později...
Třeba by Vám to pomohlo
01314 - Engine Control Module: No Communications
Possible Causes
  • CAN-Databus Wiring/Connectors from/to Engine Control Module faulty
  • Fault(s) stored in Engine Control Module
  • Engine Control Module recently flashed or re-mapped
Possible Solutions
  • Check CAN-Databus Wiring/Connectors from/to Engine Control Module
  • Check Measuring Value Blocks (MVB)
    • Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01314 - Engine Control Module: Check DTC Memory
Possible Causes
Possible Solutions
  • Check Engine Control Module for Fault Codes
Special Notes
  • Engine Control Module stored a Code which influences other Control Modules Functionality.
  • To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
Jj podle rosstechu jsem to zkousel. a chipnute auto nemam. ja mam problem v tom ze nekdy kdyz vlozim klice do spinačky tak nenastartuju a nazkoči tato chyba komunikace z jednotkou motoru.. ale udela to jen obcas.. troufam si rict ze kdyby byla chyba v kabelech tak by to za jizdy chcipalo ale to se neděje.. paradni zavada no...
A koukal jsi na ten blok měřených hodnot, jestli to neháže chyby při té komunikaci (jestli by to chcípalo nevím, auto by nemělo chcípat samo z bezpečnostního hlediska ale jen když to opravdu jinak nejde, a pokud jednotka funguje tak to jede, akorát to možná nekomunikuje s okolím....) To že to nechce naskočit, možná bude, že to zrovna nekomunikuje s immo.
Co kontrola konektoru na jednotce (není vyhnilej), přechody mezi pinem a káblem, dokonalé proměření kabel sbvazku, určitě se na to dá přijít, popis je vcelku naprosto jasný, ale je třeba zkontrolovat opravdu vše......
Ahoj diky za rady... zatim cekam az budu mit čas ja i muj znamy autoelektrikař aby jsme se dostali k ŘJ motoru a koukli na ten konektor.. meřene bloky jsem zkousel.. 10x jsem zapnul kličky a komunikace OK po 11pokusu komunikace nebyla.. a pak zase cca 10x a vždy komunikace z ŘJ motoru byla.. proste obcas si to nenajde ŘJ motoru.Když už je nastartovano tak komunikace drži pořád ps: klidne bych zajel na dovolenou :) udela to jen občas pri zapnuti kličku pak už ne. až zkontrolujeme ten konektor tak napišu... pak už opravdu nevím. jinak pokud by to delalo IMMO jak na to prijdu?? da se to nejak zjistit?? díky
Nene v autorizaku jsem nebyl... to je pro me až posledni možnost :) ale teoreticky svazek musi byt ok ně? Kdyby bylo neco přerušeno ve svazku tak to dela pořad pokud se nemylim.. a ne jen občas a po opetovnem vypnuti a zapnuti kliču je vše OK... ten soft by sedel vic ale kdo vi.. nejradeji bych to nejak odzkousel doma at vim presne co je v haji a pak to řešil.. bud sehnat druhou jednotku nebo neco jineho... nevim nechce se mi kupovat jednotku motoru když nemam 100% jistotu že chyba je v jednotce... Pomoci meřenych hodnot ve vagu je komunikace OK a když to zrovna udela a nenastartuji tak komunikace neni... ale čim to muže byt? budu moudřejší o vikendu až se kouknem jestli neni spatny kontakt v konektoru ale to se mi moc nezda to by ta komunikace z ŘJ motoru vypadla i behem jizdy přece. Ale každopadně to zkontrolujeme. Jinak da se nejak zjistit pomoci VAGU ten Immo?? nejak promerit jestli je OK?
Editováno: , autor: BiGGy
Tak může tam být studený spoj (přechodový odpor někde na konektoru) a ten svazek může blbnout jenom občas.........
To zase jo, ale věř mi, podstatně jednoduší je přehrát do jednotky novej SW než se štrachat v kilometru drátu, jestli je 100%....
Osobně bych to zkusil s tím softem a pak pátral dál, to je hrozná práce
Asi nevis kolik chcou ve škodovce za přehrani softu? podle toho co pises mi to nejvic sedi na ten soft nebo immo... ale kdo vi.. to se uvidi až přijdeme na zavadu... snad na to vikend bude stačit... až najdeme zavadu tak ji tu urcite napišu. ten svazek mi moc nesedi.. sice pises ze muze blbnout jen obcas ale to by blbnul občas i za jizdy a chciplo by to protože by auto nemelo přistup k řidici jednotce motoru.
OK diky za info.. :kol-47: Snad na to přijdeme svépomoci .zatim me to nijak neomezuje tak je to dobré... huř by bylo kdyby auto přestalo jet... Ale každopadně chci přijit na to čim to je... nejradeji bych vyzkousel druhou jednotku ale nevim jestli bude kamarad ochotny ji vyndat ze sve octavie :) No uvidime... Každopadne jeste zkusim měřit vagem tu komunikaci i za jizdy... pokud vypadne i za jizdy nebo ne... zatim ti moc dekuji . dám vedet až na to přijdem. Díky
  • o 4 týdny později...
Našel jsem na Bazoš.cz ridici jednotku:03g906016k na muj vuz tak jsem ji objednal ale pan prodavajici se asi chtel zbavit uplne jine ridici jednotky a přišla mi tahle:03g906021RH .No jo zase jsem někomu naletěl :( ale doufal jsem ze pujde zpojizdnit na mem voze..Našel jsem si klučinu ktery se v teto problematice vyzna dal jsem mu starou jednotku(03g906016k) i tu novou(03g906021RH). Nakonec mi potvrdil ze ta nova kterou jsem koupil je nepoužitelna na muj vůz.Tak jsem byl v naději že opravi tu starou. Ale ani ta nejde.Dnes jsem za nim byl ukazoval mi mou jednotku zevnitř.. žadny studeny spoj tam není.Přehral mi nejnovejší software jednotky a to taky nepomohlo.. Takže mi nezbyva nic jineho než šetřit na 3tí jednotku... Kdyby nekdo z Vás mel jednotku : 03g906016k za přijatelnou cenu dejte vědět.budu rád.. :kol-26:
