Fabia 1,4mpi lambda problem
kikitron
Hy!
I have Skoda Fabia 1,4 MPi, ATZ, 50kW, year 2000 and i have problems with my lambdasonde.
The VAG test is:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 047 906 033 A
Component and/or Version: 1,4l SIMOS3PA 00HSSJ48
Software Coding: 00021
Work Shop Code: WSC 13765
Additional Info: TMBNB46Y9Y3055240 SKZ7Z0Y0517288
2 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating: B1 S2: Open Circuit
P1118 - 35-00 - -
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-10 - - - Intermittent
Is possible to get some universal lambdasonda??
Or i have to buy only original??
If it is possible, is the Bosch lambdasonda ok and witch one? (model,number)
The sonda has 4 wire.
Sorry on my bad english.
Best regard,
Kristijan
Editováno: , autor: kikitron
Odkaz ke komentáři
Sdílet na ostatní stránky
hello,
at first my English is not good...
You must know, which Lambda sonda is Kaput...
You have two possibilities:
1. lambda probe -in front of catalyst (orig. number 047 906 262) prise 3750,-Kč
2. lambda probe -behind catalyst (orig.n. 06A 906 262AJ) prise 4966,-Kč
this prise is on authorised servise...
Odkaz ke komentáři
I think that the Oxygen (Lambda) Sensor Heating: B1 S2 is Lambda behind catalyst.
B1 - bank 1
S2 - sensor 2
Am i correct?
How much Eur,- is 4966,-Kč ?
@DIAGNOSTIK, what did you mean with " sonda KO" ??
Odkaz ke komentáři
  • o 3 roky později...
Mne Vag ukazal presne tie iste chyby, tak v servise mi vymenili Lambdu, original bosch, ale po prejdeni 5km sa kontrolka opet rozsvietila.
2 Nalezeny chyby:
17526 - rada 1 -sonda 2: topny okruh Preruseni
P1118 - 35-00 - -
16524 - rada 1 -sonda 2 Bez aktivity
P0140 - 35-00 - -
Tak som vycistil skrtiacu klapku, vymazal chyby a jazdil som. Cca po 60km sa kontrolka opet rozsvietila, ale az ked som sa presuval cca do 1km a opakovane startoval motor. Jediny problem ktory som na aute postrehol je ze dlhsie trva pokial nastartujem motor. Neviem posudit dynamiku jazdy lebo som ho uz kupoval stou zavadaou. Znami servisak povedal ze to moze byt vadny vstrekovac.
Nema niekto skusenosti s podobnou zavadou?
Editováno: , autor: transwarp
Odkaz ke komentáři
  • o 3 týdny později...
  • Pawouk uzamkl následující téma
Toto téma je nyní uzavřeno, a proto není možné odpovídat.
